should i get my 355 balance - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-08-2012, 07:19 PM
prettyboyced's Avatar
this is my 1st rebuild motor 355 stock crank .010/.010 stock rods with arp bolts and hypereutic summit brand pistons. afr 190s heads and xfi 280 .576/.570 cam so i will be shifting around 6500 rpm and already low on funds so i wondering could i get away with not having it balanced or would is something i should have done. this is my everyday driver
Old 02-08-2012, 07:23 PM
DoubleVision's Avatar
There is no telling how many small blocks I've put together and never had one balanced and never had any issues. As long as your using the correct balancer and flexplate you won't have any problems. If it were a destroker or stroker or a 400 I would say by all means have it balanced. But on 350's and smaller for street duty I wouldn't bother.
Old 02-08-2012, 07:27 PM
will it vibrate im asking my highway rpms be around 3500 and 4000
Old 02-08-2012, 07:36 PM
Richiehd's Avatar
JS-70
If it does you'll never feel it. Like Doublevision said, we've all put a few small blocks together with out balancing. I would if I changed pistons and other internal parts. Relatively spaeaking its fairly cheap, I think I paid $100 or so.
Old 02-08-2012, 07:54 PM
thanks and where im at its 250
Old 02-08-2012, 08:14 PM
Custom10's Avatar
my KARMA ran over my DOGMA
Last journal entry: SS
Rev's r the key.
<5500 walk all day with the proper build & no balance. But > 6500 wish U had paid for the bob spec results.
Some-where in the middle <---> cross your fingers.
I say get it done or,,,Maybe get a different daily driver
Old 02-09-2012, 12:45 PM
I don't know guys; this engine has a pretty good cam, really good heads and crappy bottom end. This, as us old farts know, is a learning process we all came through. Stock rods with ARP bolts hanging Summit hypers tied to a 10/10 stock crank, and I'll bet an old used stock damper and this is going to turn 6500 RPM in a Daily Driver.
If I was in the business of making SBCs into grenades, this is exactly what I'd build.
Bogie
Converting SBC External Balance to Internal Balance zildjian4life218 Engine 3 02-18-2010 01:02 PM
balance stinger460 Engine 2 07-30-2009 07:46 PM
To balance or not to balance? 564Kathleen Engine 5 12-05-2005 10:42 AM
To Balance or not???? Ratchet Engine 11 11-26-2005 10:54 PM
400 SBC balance hosep Engine 7 03-31-2005 08:21 PM
