Should I get my suspension done before my bodywork? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-02-2003, 11:04 PM
neil madsen's Avatar
BLACK BEAST
Post Should I get my suspension done before my bodywork?
Would I be better off getting my suspention done before my bodywork,or would it matter which I did first?
Later, Neil
Old 03-03-2003, 01:23 AM
zonk's Avatar
Home Built Rods No Rules
Last journal entry: Home Made Sheetmetal bender plans
Post
Depending on what your building I've always try to do suspension first in case you have to lift body or undo body parts to give yourself more room
Old 03-03-2003, 01:28 AM
Frisco's Avatar
Glad To Be Here
Post
[quote]Originally posted by neil madsen:
<strong>Would I be better off getting my suspention done before my bodywork,or would it matter which I did first?
Later, Neil </strong><hr></blockquote>
Yes!!!
Old 03-03-2003, 03:40 AM
adtkart@aol.com
Post
As a general rule, I usually do the body work last. You can run into problems with paint not wanting to stick if you do the body work before mechanical work. Almost impossible to avoid touching the primered surface. You sure don't want to have it painted then have to do major mechanical work and chance messing up the paint.
Old 03-03-2003, 03:59 AM
4 Jaw Chuck's Avatar
Post
Yep!
— Han Solo
Old 03-03-2003, 12:14 PM
F-1Rodder's Avatar
Post
You not only want to do the supension work first, but also wheels, tires and suspended weight loads need to be mocked up or real. You want to build the car generally from the bottom up, get it driveable and the last thing you do is finnish work.
Old 03-03-2003, 12:36 PM
BLACK BEAST
Post
Good thing I asked before I did <img src="graemlins/sweat.gif" border="0" alt="[sweat]" /> I guess my suspention will be the first thing I will worry about.
Thanx a bunch guys
« 7" booster | brakes »
