Should I go ahead - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-27-2006, 05:29 PM
Last journal entry: Long time no journal entry, pulled hood tonight.
Should I go ahead
Should I replace the U joints on the driveshaft while I am replacing the tranny on my 74 coupe deville?
Old 07-27-2006, 06:24 PM
Jmark's Avatar
I dunno, are they bad? sticky, creaky, squeeking, clunking, showing red rust dust around the caps? Do you have a constant velocity type drive shaft? If so, the center pin could be worn too and the shaft will need rebuilt by a reputable driveline shop.
Old 07-27-2006, 10:16 PM
sbchevfreak's Avatar
Licenced Automotive Technician
IMHO? Absolutely. You already have the shaft off, and I have seen joints that did not seem bad fail "all of a sudden". Ujoints are cheap, and why crawl under the car later when your already there now?
Old 07-28-2006, 10:30 AM
Thanks
I will probably replace them then. Though I may have to because I am thinking about having a new driveshaft cut. I have a Switch Pitch TH400 and am debating putting it in or rebuilding the original TH400. But the switch pitch is shorter. I still have not made up my mind which way to go.
well getting ready to get serious on the 37 37ford4dr Hotrodding Basics 107 04-13-2016 09:25 PM
Why not put the coil springs ahead of the axle? FrankR Suspension - Brakes - Steering 2 08-24-2005 09:02 AM
4th of July plans? killerformula Hotrodders' Lounge 22 07-02-2005 02:38 PM
New Years! Chevy Thunder2 Hotrodders' Lounge 30 01-01-2004 09:21 PM
wife says go ahead and build...... beast32 Hotrodders' Lounge 11 09-25-2002 08:55 AM
