Should I install an electric fuel pump - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-24-2007, 08:35 PM
So here is the deal; I have a 153" Chevy 4 banger in my '29 that sometimes sits for long periogd without being started or driven ( I know the answer to my question is drive it more!) that when I do try to start it it seems as if the carb is dry and pumping the pedal only seems to flood the engine (too much carb but looks cool)!
I am wondering if installing an electric fuel pump would solve my problem by filling the carb bowl and injecting the small fuel mix it seems to take to start the engine.
All help is appreciated.
29guy
Old 12-25-2007, 06:06 AM
bondo's Avatar
Ayuh,.........
I don't think going to an electric fuel pump is going to Fix anything......
For 1 thing,..... It Isn't going to "injecting the small fuel mix it seems to take to start the engine"........
That's the job of your Over-sized Carb.......
Going to a smaller Acc. pump in the Carb might Help.......
'course,..... Making sure the Choke is Working,+ Adjusted properly is a given.......
And,........
If the Carb's Bowl is going Dry,.......
Just turn the motor over 5 or 10 revolutions,+ the Mechanical Fuelpump will fill it Just Fine..........
Then setting the Choke,......
It Should start right up.............
Old 12-25-2007, 08:15 AM
31 five window
Last journal entry: grill and rear end
I agree with bondo that you have other problems,but a lot of old cars seem to have the problem of carb going dry when layed up.Most run an electric pump just to fill the bowl then turn it off and run on the mechanical pump as it will pull through the electric one.As he said this will not inject fuel ,only the accelerator pump will.So once bowl is filled be sure not to pump it too many times. But he does make a good point to make sure your carb is in proper working order and choke is set right as the electric pump addition is only a bandaid solution, but it works.
Old 12-25-2007, 09:46 AM
Bondo and Speedydeedy,
Thanks for the replys and merry Christmas.
29guy
Need help on converting to electric fuel pump!! texastomeh Engine 5 04-09-2007 11:01 AM
Fuel Pump Not Sending Gas To Carb Why?? Its Not Electric Fuel Pump???? zeeman19 Engine 7 02-13-2007 04:17 PM
Helper electric fuel pump to aid my mechanical?? hotrodf1 Engine 4 06-06-2006 08:39 PM
93 Suburban fuel pump sabino56 Engine 8 09-10-2005 03:54 PM
HELP QUICK Electric Fuel Pump Leaking 66 T-Bird Engine 4 06-06-2005 07:26 AM
