Should I keep my hydro-boost brake system?
I am doing a build up on a Chevy Suburban that came equipped with a hydro-boost braking system.I am replacing the diesel engine with a 427.
The hydro-boost system works flawlessly but the repair parts for it, when it does go bad, are a bit expensive.I have a donor truck with all the components necessary to switch to a vacuum assist brake system. The truck is being built for performance but will occasionally see towing duty. Does the hydro-boost system have any advantages that I am not aware of? Also, I originally intended to switch to a quicker steering ratio. Would that be possible if I keep the hydro-boost system, since the power steering system is tied into the brake system? |
Come on guys.
Somebody has to be familiar with this system. I really need the advice.:drunk: |
http://www.gmc.com/gmcjsp/yukon/spec...=yukonxldenali
http://www.stu-offroad.com/brakeconv/bc-7.htm http://subtopics.freeyellow.com/Brakes.htm http://autos.groups.yahoo.com/group/hotrods/message/782 http://www.fourwheeler.com/techarticles/54701/ here's a few sites I found on them, hope it helps. cant personally tell you about them but I do know they'll throw you through the windshield if there's a panic stop. They're must better then regular power brakes, but like you said to rebuild or replace it aint cheap..........joe |
Thanks Joe!
Those links helped alot. I have decided to keep the system since the truck will see occasional towing duty.The extra cost in parts should be worth it since, now I know, that my system provides extra braking power without any variations. :thumbup: |
| All times are GMT -6. The time now is 09:25 PM. |
