should i line-x the whole damn thing or what? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-28-2004, 11:26 AM
New Member
having a convertible 4x4 like my 78 bronco can cause all kinds of problems from mud and water flying in to leaves and crap falling in when its parked and my rubber matting all over the truck is cracking from UV exposure so...should i line-x the whole damn interior, or would this make it unbearably loud? anybody got any good ideas on tuff interior options for me?
Old 07-28-2004, 11:44 AM
poncho62's Avatar
Wiki Edits: 5
Can't get much better than rubber. Throw a tarp over it when not in use. That will help save it from the UV damage.
Old 07-28-2004, 03:09 PM
Kevin45's Avatar
Just one of the guys
Last journal entry: Vise jaws
Stacy David did it to Crazy Horse on Trucks.
Kevin
Old 07-29-2004, 12:51 AM
New Member
so i should just do it then? who cares about noise anyway right....just get a louder stereo
Old 07-29-2004, 09:33 PM
daimon1054's Avatar
The linx is a pretty good noise barrior so it should not be to loud, more than what you have but if there is not top just how much can hear other than wind
I say go for it!
Old 07-30-2004, 12:38 AM
New Member
i cant hear nuthin but wind and little chevy's screaming as they get ran over.......
Old 07-31-2004, 01:24 AM
I'm just finishing up my 86 F150 and decided to try out undercoating on the floor (rubberized, similar to Line-X).
It turned out great, and I'm hoping that it will keep the floor pan from rusting out the way it had prior to the resto. I've sandblasted the underside, coated it as well, and hoping this will give me a good sound barrier. The old tin floor was rusted out under the mats, and esp. where your heels go (such as clutch pedal, gas, etc...).
Hard to get a good view with the waterspots on the lens, but loving the coating already
Old 07-31-2004, 03:24 AM
jeeptuff's Avatar
**** or get off the pot
Do It
I did the entire interior tub on my 83 K-5, I did all the prep work (pulled the seats and media blasted the inside) then took it to the local Rhino Lining facility and had them shoot it. Line-x is good but after using Rhino Lining in all my pick ups that is the route I went. Good luck to ya..
Old 07-31-2004, 11:35 AM
New Member
i knew it had to have been done by someone. the underside of my bronco has already been sprayed with some sort of rubberized coating, but what sota prep do the rhino liner/line-x guys want done before they will spray it on the interior? i assume i should sandblast it or something. some of the floor is rusting out but just little spots-will the coating just fill the little holes or should i replace the floor pan? and what the diff. between rhino liner and line-x? and do they come in different colors? it gets to be 115 degrees here in chico and the black could turn my truck into a solar oven! thanks for the response.
Old 07-31-2004, 01:51 PM
Rhino Lining, Line-X, Hippo Liner, etc... may not inhibit the rust, just seal it in for a bit while it works away at eating more of the floor pan (although on their web site they do state: "By forming a permanent bond with the surface of your truck bed, the lining prohibits rust, corrosion and surface abrasion from damaging the truck..."). Personally I would get rid of the rust anyway possile, wether it be replacing the floor pan, using Rust-Mort, or whatever...but get rid of it, not just seal it in.
My thought is, if you just cover it up for now, it will come back, and even if you plan on selling later on, somebody else will inherit the underlying problem.
I don't know specifically what Rhino Liner or the other companies want done as prep work (our nearest facility is 4 hours away), yet a friend decided to try some Hippo Liner on his fender flares and bottom panels of his S104x4...and it ended up peeling off. He said he scuffed up the paint...
I ended up replacing most of the floor pan in my truck, sandblasted the metal that was still good, DA sanding everything down (rough sanding where the liner was going), and sprayed the floor pan with a rust proofing/inhibitor primer (from Rust Check) prior to using the undercoating. I don't know if it was the right way, but figured the rust inhibitor would keep any micro traces of rust left on the old metal from activating again if any oxygen does get to it through the liner, and the liner should have a good bond to the primer (I hope).
Rhino Liner and others do have various colours available, so you can go with whatever colour is available (only thing, light colours may show the dirt quick) and hopefully keep the truck a bit cooler in that heat (must be nice... trade ya some of our cooler temps...).
In addition to black, red, gray and blue linings are often standard at dealerships. The linings can also be custom dyed to match your exact color specifications.
Rhino Liner FAQ
