should I lock out timing ? BBC 454 - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-14-2011, 07:59 PM
truckboy61's Avatar
I got a 66 elky with 454 .30 , stealth intake, 206 closed chamber heads with .020 gaskets, dished pistons, th 350 trans go kit, 2800 stall , 456 posi rear, MSD 6al box and pro billet distributor with vacum advance,cam is a comp cam 294s solid lift . I ask about locking out timing because at idle vacum is at 7 hg vacum ? i just got a bushing and spring kit so I can recurve distributor as need be please help
Old 07-14-2011, 08:31 PM
truckboy61's Avatar
thanks i have a after market smaller high torque starter I was thinking about adding a kill switch from my msd box ? since Im using the magnetic pick up is it the red or white that would get switch
Difference between non-lock up and lock up transmissions beside the torque converter cool rockin daddy Transmission - Rearend 14 06-16-2011 08:25 PM
Timing sbc corvette timing at 12o clock on both gears? 85 vette Engine 21 12-22-2004 09:23 PM
trying to setting the timing on the timing chain and gears on a 74 ply with a 318 ReggieN Engine 1 10-05-2004 08:54 AM
Trust the timing light or the timing pointer? lluciano77 Engine 6 03-06-2004 02:35 AM
Question about AOD.......lock up vs. non lock up Carbed95GT Transmission - Rearend 4 01-18-2004 06:17 PM
