-   -   should I primer before I powder coat (http://www.hotrodders.com/forum/should-i-primer-before-i-powder-coat-226391.html)
peteandrepete232 11-22-2012 06:47 PM
I'm getting ready the frame sandblast and powder coat the frame of my model A I've had people tell me that I need to primer before I send it out to be powder coated and I've had people tell me I don't any suggestions
novafreek6872 11-22-2012 07:10 PM
I was under the impression that parts are powdercoated straight after sandblast...
OneMoreTime 11-22-2012 08:00 PM
All the paint needs to come off before you powdercoat//
Sam
MARTINSR 11-22-2012 09:08 PM
Make that all paint and primer, everything, it gets sandblasted and then they powder coat. And if you haven't contacted them most all powdercoaters do the sandblasting themselves and it is usually very cheap. Around here powdercoating costs VERY little more than having someone just sandblast it!
sunsetdart 11-23-2012 05:41 AM
Anything to be powdered MUST be BARE metal. Most of the expense in getting parts coated is the time it takes to remove all the paint with a bead or sand blaster.
69 widetrack 11-23-2012 05:45 AM
I will confirm, everybody here is correct...just love a thread where everybody gives the OP sound advice...thanks guys.
S10xGN 11-23-2012 10:15 AM
This always made me wonder how they do two-tones and overlays. Do they coat, mask, blast again and coat or just mask and coat straight over the previous color?
Russ
sunsetdart 11-23-2012 05:29 PM
To do overlays and 2 tones the part is covered first in one color and after it cures ,it is reheated. Then it is either taped off with high heat tape or the other color is sprayed to blend the first color into the next.
