should I primer before I powder coat - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-22-2012, 05:47 PM
chris
I'm getting ready the frame sandblast and powder coat the frame of my model A I've had people tell me that I need to primer before I send it out to be powder coated and I've had people tell me I don't any suggestions
Old 11-22-2012, 06:10 PM
novafreek6872's Avatar
Nova Guru
I was under the impression that parts are powdercoated straight after sandblast...
The Following User Says Thank You to novafreek6872 For This Useful Post:
peteandrepete232 (11-22-2012)
Old 11-22-2012, 07:00 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
All the paint needs to come off before you powdercoat//
Sam
The Following User Says Thank You to OneMoreTime For This Useful Post:
peteandrepete232 (11-23-2012)
Old 11-22-2012, 08:08 PM
Make that all paint and primer, everything, it gets sandblasted and then they powder coat. And if you haven't contacted them most all powdercoaters do the sandblasting themselves and it is usually very cheap. Around here powdercoating costs VERY little more than having someone just sandblast it!
The Following User Says Thank You to MARTINSR For This Useful Post:
Old 11-23-2012, 04:41 AM
Last journal entry: 50 Ply wagon
Anything to be powdered MUST be BARE metal. Most of the expense in getting parts coated is the time it takes to remove all the paint with a bead or sand blaster.
The Following User Says Thank You to sunsetdart For This Useful Post:
Old 11-23-2012, 04:45 AM
Faith - Respect - Trust
I will confirm, everybody here is correct...just love a thread where everybody gives the OP sound advice...thanks guys.
The Following User Says Thank You to 69 widetrack For This Useful Post:
Old 11-23-2012, 09:15 AM
S10xGN's Avatar
Gotta love a turbo!
This always made me wonder how they do two-tones and overlays. Do they coat, mask, blast again and coat or just mask and coat straight over the previous color?
Russ
The Following User Says Thank You to S10xGN For This Useful Post:
Old 11-23-2012, 04:29 PM
To do overlays and 2 tones the part is covered first in one color and after it cures ,it is reheated. Then it is either taped off with high heat tape or the other color is sprayed to blend the first color into the next.
Anyone use Redi-Coat in Michigan to dip strip and e-coat primer your body shell? Chuck78 Body - Exterior 5 09-03-2011 06:08 PM
Powder coat TEXAS'55 Hotrodding Basics 1 02-14-2007 10:39 PM
powder coat rlvirago Engine 4 07-12-2006 08:15 AM
Need Some Powder Coat cfatrat Body - Exterior 5 01-30-2006 07:47 AM
UV Powder coats- "Powder coat Bill". BarryK Body - Exterior 1 05-17-2005 08:54 AM
