Yes...the longer pad goes to the rear.
If the bearings look good, not pitted, I would reuse them. Check the races too
Ontario Rodders |
Yeah I'd just check them and reuse them if cost/time is a concern. My truck is around 250,000 miles and it's been on it's third set of bearings for about 10,000 of them. If you want peace of mind, though, there's nothing wrong with replacing them.
I was reading the rock auto news letter yesterday and there was a customer story about a guy who bought a ford truck cheap because the back brakes locked up unusually under normal conditions. He replaced the shoes and didn't know they were on backwards so he put them on backwards AGAIN copying the old brake job. When they locked up after the brake job he just adjusted them out so that they wouldn't do it any longer. Took 3 years later at a vehicle inspection for someone to notice it. Long story, but yeah, thicker pads to the back. |
If it's better to replace them I will. Just trying to be practical and not waste. Looks like I'm getting opinions both ways. Same thing my brain was doing and the reason I asked. It's the front I'm referring too. I'm wasn't planning on doing anything with the rear bearings until I get a seal leaking or noise. I've never seen a rear wheel bearing failure that didn't give a noise warning first. |
I just noticed if was the front Brgs you were talking about so ignore my brg numbers I gave you
![]() I would still replace them if it's original stuff. Better to be safe than sorry. |
If I was at all concerned, I would just replace them. Better to know their good then to worry about them on the road. I've used the Autozone Timken bearings in quite few applications, it's usually what I go with.
I think I've lost my concern. After cleaning them, they look new. No lines or colors at all. I also started thinking that this is a decision that can be made next time it needs brakes. Everything comes apart and has to be cleaned anyway. I wouldn't ever put new pads on the front without turning the rotors.
Again, maybe I'll give this more thought at the next brake job. I don't put many miles on this car, but I do want it safe and reliable. Btw, this is an original Choo Choo SS car and is fairly rare for a 1983 model. I put an LT1/4L60E in it back in 1998. The engine and transmission came out of a '96 Impala SS that was taken out of the car when it only had 100 miles on it. I've only put 25K miles on it since then. I did the rear gear change at the same time. I thought you guys might like to see the car we're talking about. Pics always make a thread more interesting. ![]() ![]()
Very nice
If your bearings show no wear or discoloration then go ahead and reuse them. The important thing is that you get enough grease between the rollers when you repack them. You've got disc brakes on the front so make sure you use the proper type grease. You might want to replace the seal before you put it back together. It's just cheap insurance. Adjust the bearing nut to the right spec after tightening it tight to seat the bearings and back it off. Then re-tighten to the proper spec. The reason your bearings look so good after 80K is because someone has been doing a good service job all along.
BB |
| Replace bearings after crush or put them back where they came from? | DaSouthWon | Engine | 4 | 03-23-2009 01:04 PM |
| Wheel bearings | atlantis | Suspension - Brakes - Steering | 8 | 01-31-2005 06:06 AM |
| wheel bearings | stoney 81ta | Suspension - Brakes - Steering | 2 | 03-20-2004 05:56 AM |
| packing wheel bearings | chevynut | Suspension - Brakes - Steering | 12 | 01-10-2004 06:58 AM |
| Front Wheel Bearings | black66 | Suspension - Brakes - Steering | 10 | 06-02-2003 08:31 PM |
