Should I still lock out the Distributor - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-14-2013, 04:31 PM
Slammedsi's Avatar
I am in the process of replacing a comp thumpr cam with "2" different cams. I bought the Isky 270H on a recommendation of a board member. But i found a crane cam p/n 10017 that looked like it would be a good choice also. I know its childish, but i really like the lope at idle. So I was looking for a cam that would better suit my compression ratio and have that lope we all like. The Crane cam is 218/218 106 LSA. I noticed summit made the same cam for half the price. At 75 bucks i didn't feel like i was loosing much if it wasn't the one for me.
Now on to my question. Right now with the Comp Mutha thumpr, 235/249 @ 50, 107 LSA cam i have now, i have the dizzy locked out 36* total timing. With this smaller cam, Should i keep it locked out?
Edit: here is the Cam in question.
http://www.summitracing.com/parts/sum-1785/overview/
Old 04-14-2013, 05:08 PM
spinn's Avatar
Everybody likes the lope at idle.
The Following User Says Thank You to spinn For This Useful Post:
Slammedsi (04-14-2013)
Old 04-14-2013, 06:22 PM
Slammedsi's Avatar
I know a lot of different people catch flack for stating they want a cam that lopes. I.E. Not looking for the performance aspect of it.
Old 04-14-2013, 06:54 PM
vinniekq2's Avatar
If you want the cam to lope,then build the rest of the engine to match a decent cam?
Old 04-14-2013, 07:20 PM
Slammedsi's Avatar
that's the plan with a short block i have set aside. Progress wont start till later on that motor. Thanks for the advice Fbird. Most likely will.
Old 04-14-2013, 07:57 PM
Slammedsi's Avatar
Originally Posted by F-BIRD'88 View Post
The smaller cams will probabily not need full locked out timing.
More like 22-26deg at idle and 36deg at max advance. ( a 10-12deg advance curve)
Just stick the Isky cam in it. Degree it in on a 104 in C/L.
Fbird, What would happen if i try keeping it locked out at 36* on the smaller cam?
Old 04-14-2013, 08:35 PM
Slammedsi's Avatar
You will upset the Space-time continuum
I just spit beer all over my computer.. Thanks haha
Old 04-15-2013, 05:35 AM
Last journal entry: Accessories can drive you mad
Nope. I like a smooth idle. That means the tune is correct.
Old 04-15-2013, 09:36 AM
spinn's Avatar
Even though you chose a cam with more overlap, you can still tune it.
Not sure, what this guy is communicating.
Old 04-15-2013, 09:51 AM
Banned
and destroy your engine...
If that matters at all.
Old 04-15-2013, 09:57 AM
spinn's Avatar
This cam , 218/218 106 LSA , locked out with 36 degrees timing will destroy itself?
AP, Tell me more.
The original post , had a big cam. Decided he liked the idle sound, but wanted something more reasonable. I respect that.
I don't understand why not just retime it. I took this as a what if question.
Old 04-15-2013, 10:16 AM
Banned
AP, Tell me more.
too much advance will cause detonation, and will cause the weakest link to fail- could be a head gasket, piston ring, piston, bearing, rod, a multitude of things.
Lets try it and find out- its not my engine.
Old 04-15-2013, 10:22 AM
spinn's Avatar
Too much load at too much advance causes detonation.
The advance alone is not going to do it.
Im at a disadvantage, I don't know what this is do you?
I believe the best timing advice was given in post 3. On what will happen if he left it 36. the hypothetical question. I don't see destruction.
Old 04-15-2013, 10:39 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Thing is, if you like the lope, LESS timing at idle will help. Locking the timing w/a 218/106 lsa cam is unnecessary- you could prollably use 16 degrees initial and get by just fine, and increase the lope to boot.
Some info on timing, etc: Ignition advance.
Old 04-15-2013, 10:46 AM
spinn's Avatar
Driving around retarded isn't much fun.....or is it?
Difference between non-lock up and lock up transmissions beside the torque converter cool rockin daddy Transmission - Rearend 14 06-16-2011 07:25 PM
How to lock distributor ?? Ratoflic Engine 1 09-10-2010 02:57 PM
How do you lock out a Distributor cowbay Engine 3 10-31-2009 10:26 PM
MSD Box Lock out distributor cowbay Engine 6 10-29-2009 10:58 PM
Question about AOD.......lock up vs. non lock up Carbed95GT Transmission - Rearend 4 01-18-2004 05:17 PM
