Should i switch to 3.73's?????
hi im 15 and i have a 1991 gmc suburban with 33 in tires
im rebuilding the motor right now and it should be around 300 hp when im done im not sure what the rear end ratio is in it now but im sure its stock before i started building the motor the burban had no power and bad gas mileage (around 10) my question is would a switch to 3.73's help my around town power and gas mileage? i wont be doing to much hiway driving but i dont want to be on the hiway running 3500 rpms or something. So should i switch to 3.73's with my 33 in tires? thanks for any imput |
what is the easiest way to check?
thanks
i will check that but say i have lower gears than that what should i do did any suburbans 87-91 come with 3.73?? |
it is a half ton 8.5 in 10 bolt rear
Im not 100% sure I know I have a 1995 burban and it has 3:55 gears not 3:73's I also have a 1991 blazer that has 3:55 gears. It may have it may not have the only way to find out is to count the teeth. its an awfull stinky job but it helps to know the gears. I know i have a 1984 chevy fullsize with 2:56 gears *gags* Im swaping them out for 5:13 lockers
Been discussed many times. A quick run of the search feature yielded this (one of MANY).
How to determine gear ratio in Ford 9" |
Ya 8.5 in but not a 10 bolt it was a 12 bolt that had the 4:11's its been awhile since Ive done one.... Im trying to knock the cobwebs out and remember how to do it!
| Trinary Switch from Vintage Air | ElegantInventor | Electrical | 29 | 06-15-2011 06:44 PM |
| fitting switch nuts and knobs to short shaft | TheCiscoKid | Electrical | 4 | 03-28-2008 03:58 PM |
| Roll Bar Install Advice | Mustangsaly | General Rodding Tech | 12 | 12-02-2007 08:33 AM |
| 72 chevelle ignition switch assembly problems | customdrumfinishes | Electrical | 9 | 08-10-2006 05:06 PM |
| Starter switch stock to modified wiring question. | Kallie49 | Electrical | 5 | 06-23-2006 06:01 PM |
