Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Should I use a gasket sealer on a .015 shim head gasket?
Old 08-23-2012, 06:51 AM
Caprice Sleeper's Avatar
Caprice Sleeper Caprice Sleeper is offline
Thanks for the help. I couldn't find the GMPP head bolts. Before I made the thread I was planning on using Fel pro (FEL-ES72856) Cylinder head bolt kit $23.95. Seems like they will work but I would like to get your input on them and the GMPP parts number if you have it. Also I don't want to run into trouble with my intake gaskets cracking because I milled my heads. I checked out the Fel-pro 1255 gaskets you told me about. Once again before the thread I was going to use Edelbrock (EDL-7235) intake gaskets $24.95. I think I will go with the Fel-pro's, they seem like a better gasket for my application. Thanks for the help.
