should mechanical fuel pump be primed? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-05-2010, 10:04 PM
gto_ron's Avatar
I'm restoring a 64 GTO. New gas tank, fuel lines and I rebuilt the stock mechanical fuel pump. It's not pumping gas to the carbs and I wonder if I should siphon gas to fill the new fuel line to ensure the pump is getting fuel.
Ron
Old 09-05-2010, 10:45 PM
F-BIRD'88's Avatar
Yada Yada Yada
The pump and fuel lines should self prime. Disable the spark 12v power and kick over the engine for 30sec bursts for a few times. It takes a bit to fill the system the first time. It will fill. Did you install the push rod?
Old 09-06-2010, 07:04 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The Pontiac uses an eccentric bolted to the nose of the cam and a self-contained arm on the fuel pump- no p-rod needed.
excessive backfire and flames! also rocker arm knock chevykid90 Engine 53 08-27-2010 04:42 PM
Mechanical Fuel Pump Shag0215 Engine 4 03-12-2010 11:56 AM
Help - my fuel pump is leaking KENMO Engine 10 07-01-2007 12:39 PM
carburetor leaking; fuel tank needs cleaning islandman General Rodding Tech 7 03-17-2007 06:03 PM
!!!!! HELP - CARBURETOR LEAKING & FUEL TANK NEEDS TO BE CLEANED!!!!!!!!!!!!!!!!!!!!! islandman Engine 3 03-17-2007 03:36 PM
