Should you re torque bolts after a while? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-08-2004, 11:15 AM
Jag Daddy's Avatar
1969 Mustang Coupe Project Car
Last journal entry: New Project Mustang, From Jag Daddy to Stang Daddy
I was wondering if you should go around and check and re-torque your intake and other bolts on the engine after 20,000 miles or so?
Regards
Mark
Old 04-08-2004, 11:22 AM
Robbie's Avatar
Last journal entry: nova
Yes i would re-torque or at least go over the intake bolts, so you want get a vacuum leak,,and all the other bolts so you want get a oil leak. I always recheck my bolts after it gets hot or runs for a while.
Robbie
Old 04-08-2004, 11:25 AM
Jmark's Avatar
If you used good quality head gaskets and they are advertised as "no re-torque", then I don't.
As for all the other stuff? I'll ck them once after the install. Intakes usually are ok, but the headers are ALWAYS loose.
Old 04-09-2004, 12:03 AM
If you're using cork valve cover & oil pan gaskets, they usually need a little tightening after a year or so.
