Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - show me your home made tools so I can copy them!
  #42 (permalink)
Old 09-16-2009, 04:00 PM
OLNOLAN's Avatar
OLNOLAN OLNOLAN is offline
Tamper proof idle mixture screw tool
Here is another; the smog quadrajets have the plugged idle mixture screws. Once you get the plugs out, then you have to deal with a recessed tamper proof screw. I've run into torx style and the flat blade style. I used an old brass vacuum fitting, filed a flat groove to fit the idle mixture screw. I later crimped it onto an old GM points adjusting tool for flexability. Cost $0.00
