Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - show me your home made tools so I can copy them!
  #43 (permalink)
Old 09-29-2009, 06:34 AM
67Mustang Al.'s Avatar
67Mustang Al. 67Mustang Al. is offline
Back yard super tool.
Originally Posted by OLNOLAN
Here is another; the smog quadrajets have the plugged idle mixture screws. Once you get the plugs out, then you have to deal with a recessed tamper proof screw. I've run into torx style and the flat blade style. I used an old brass vacuum fitting, filed a flat groove to fit the idle mixture screw. I later crimped it onto an old GM points adjusting tool for flexability. Cost $0.00
while the Mustang is wating for its body to shine again i have found a new use for the 347. Chev enthusiasts would say thats all the Ford is good for.
