Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - show me your home made tools so I can copy them!
  #164 (permalink)
Old 10-06-2010, 07:22 AM
gow589's Avatar
gow589 gow589 is offline
the Clever Turn Signal
Originally Posted by Duntov
I want an integrated panel and a pig tail on mine.
The first thing I used it for was to learn the headers I made put it nice, bad.
I hooked up individual EGT's more to play with then anything. I spent an enormous amount of time calibrating them in a Kiln.
When I ran the engine at a set RPM I found 1/2 the cylinders running temps over 2x the others. I thought my equipment was set up wrong. I swapped probes. The swapped probes showed the same temps.
After looking at the headers I realized the firing order and pairing were causing back pressure in 1/2 the cyl. The headers were built from scratch and I had them ceramic they will look nice on the wall when I hang them.
When the car is painted, I have another set to try. I am not getting these coated till I test them.
