show me your home made tools so I can copy them! - Page 12 - Hot Rod Forum : Hotrodders Bulletin Board
  #166 (permalink)
Old 10-06-2010, 08:34 AM
cboy's Avatar
Last journal entry: Finished
...That makes everything I have ever made rolled all into one look like a piece of crap.
I'm with you Brian. I think Pugsy and GOW just raised the bar about two feet in terms of tool fabrication. You guys do nice work...(and I'll be first in line for when GOW publishes plans for that engine stand/diagnositcs center.)
Always learning...and sharing what I've learned. The Scratch-Built Hot Rod.
  #167 (permalink)
Old 10-06-2010, 10:25 AM
Originally Posted by Duntov
That is an excellent set up. I get the impression that you may not have realized the header problem otherwise. I imagine it takes hundreds of R&D hours to produce a State of the Art fixture that yours will be, when all said and done and polished up.
Very impressive looking set of headers..must have been a bit sickening, but offset by your instruments catching it.
I hope you keep us up on future development.
I should have caught it. I felt like a dope for not even looking at it before I constructed it. When the light bulb came on it hit me like a spot light it was so obvious.
  #168 (permalink)
Old 10-06-2010, 10:47 AM
I don't think I could really market what I have. It's all a bit of a hack. My education for electronics and computer programing is google. It has been tremendously rewarding when you get something to work.
Values for most sensors from temperatures to egt's are read in circuits and fed in through HID devises. HID is human interface device such as joy stick. Getting the code to read that was the hardest for me.
This is an analog reader which reads 8 channels of individual data. I use 2 of these:
http://www.endurance-rc.com/analogreader.html
Individual circuits calibrated to read things like EGT, O2, temps, etc modify the voltage on each channel and returns a value.
Egt values from AD595:
http://www.analog.com/en/sensors/ana...s/product.html
The RPM and timing advance is calculated with a PAK-VII chip
http://www.awce.com/pak7.htm
then processed and sent serially to the program via an OOPIC micro controller(similar to basic stamp)
http://superdroidrobots.com/pics.htm
  #169 (permalink)
Old 10-10-2010, 12:15 AM
Sandblasting cabinet
Very hard to compete with the engine test station but has got to be the best homemade tool I have ever seen.
As for me, I needed a blasting station for my up coming project and didn't want to pay hundreds for one if I could possibly build one.
I had a plastic (probably nylon to be exact) 55 gallon drum just sitting around so I decided to turn it into a sandblasting cabinet. Figured it would work well for when I want to convert to glass blasting media. The glass shouldn't break down as fast. Used the largest toilet floor flanges I could find to be able to fit my big elbows in. Going to be clamping some thick Hobart fire retardant welding sleeves inside. This way I can just slip a pair of gauntlet gloves in and they should be held in place with the elastic around the wrist and easily changed when needed. Was going to use all wood at first but opted for the drum when I started thinking about the hopper.
Name:	2010-10-08 20.51.49.jpg
ID:	48766   Click image for larger version
Name:	2010-10-09 23.38.18.jpg
ID:	48767   Click image for larger version
Name:	2010-10-09 23.38.37.jpg
  #170 (permalink)
Old 10-10-2010, 03:54 AM
deadbodyman's Avatar
Wiki Edits: 11
Thats a great use for a plastic drum (one of the best) but your wife is sure gonna be mad when she goes to use her oven and theres no racks in there...Let us know how That works out for you,I'm running out of excusses myself.
  #171 (permalink)
Old 10-10-2010, 08:20 AM
That's cool!
  #172 (permalink)
Old 10-10-2010, 09:25 AM
But without the sophisticated system who would ever know! They looked like they made sense, how many times do we design something that would look just as good but never know they weren't as good as we think without something like you diagnostic equipment? I mean, what would the headers I made for my truck back when I was 18 out of a pair of discarded 340 Duster headers look like to your system? LOLOL, I am glad I didn't know how bad they possibly were, I was damn proud of them!
  #173 (permalink)
Old 10-10-2010, 09:32 AM
Well these will look nice hanging on a wall (ceramic coated)!
  #174 (permalink)
Old 10-10-2010, 11:48 PM
Metal stock band saw lubricator
Thanks for the compliments on the blasting cabinet.
Coming back and reading the posts in here reminded me of another tool I am planning to make. Actually more of a mod. I have a cheap metal stock band saw that cuts dry. I would like to install a lube system on it to help cuts and blade life. Anyone got some pictures of a saw lubing system I could take a peek at and maybe some suggestions?
  #175 (permalink)
Old 10-11-2010, 05:22 AM
67Mustang Al.'s Avatar
Band Saw
Hi
I taught in a metal workshop in another life. We had a metal cutting bandsaw as part of the workshop equipment. It had a small spout or nozzle located on a flexible arm (similar in appearance to a drill flexi drive) pointing to the table where the blade ran through the top and disappeared underneath. The flow of coolant (soluble oil + water= white cutting compound) was adjustable with a small in-line tap. The cutting compound was collected in a sump underneath and recirculated by a small submersible pump. The fluid would travel down past the blade ( just a bit more thatn a drizzle) A tray underneath shaped like a very wide /flat funnel had a plastic tube in the centre which directed the cutting compound into a square metal can with a submersible pump.
The metal cutting bandsaw also had a pair of brass stops or backing plates located behind and to each side of the blade to allow you to push metal onto the blade without the blade wandering.
From memory the bandsaw also had a butt welding joining device as part of the machine. This allowed rejoining of the blade after the many brakes that occur due to blade binding or simply suffering from metal fatigue.
You need some aluminium sheet, a low voltage pump , an in-line valve, a fluid nozzle and some brackets to fasten everything in place.
Cheers
al.
  #176 (permalink)
Old 10-11-2010, 05:55 AM
Wiki Edits: 11
maybe an aquarium pump would work ???
  #177 (permalink)
Old 10-11-2010, 09:37 AM
evolvo's Avatar
Heathen
just one of many options:
http://www1.mscdirect.com/CGI/NNSRIT...01049&PMT4NO=0
  #178 (permalink)
Old 10-11-2010, 05:00 PM
Check your spark plug gaps
awesome suggestion, I would have never thought of that
  #179 (permalink)
Old 10-11-2010, 05:11 PM
Show me the money !
[QUOTE=gow589]I built an engine test stand....No big deal there, but then I built a circuit and wrote a computer program to read parameters. Does that count as a tool?
HOLY GOW Batman ! That is awesome.
  #180 (permalink)
Old 10-11-2010, 07:54 PM
For the bandsaw pump, I think I'd try a small water fountain pump. You can submerse it right in the drain tank. Pretty cheap too.
Can you help me out? Looking for home made (or modified) tools or garage stuff toddwallace Hotrodding Basics 4 05-26-2010 08:57 AM
Home made 700r4 transmission tools 1955Olds Transmission - Rearend 2 09-10-2009 01:02 AM
