Hey S10xgn,
Great Pressure Bleeder , By Applying Pressure Through The Master Cyl. Does That Bleed It Too While Doing The Break Cyls?? Thanks , Roger |
Russ |
I got a bugg with that exact problem I'll try it and let you know but it should work
Would The Home Made Pressure Bleeder Still Work Through A Combination Valve W/( Residual,metering And Proportioning)
I Would Think It Would Being Under Pressure, Whats Anybody Think ? Thanks, Roger |
Shane |
Hmmm,I was restoring a 69 rustang when I came up with it....
This lucky Dogs Dad bought this for him when he was 16yr (his first car) brand new...he's had it ever since...a 429 or 8 CJ Real nice shape....
i tool that i manufactured was a set of punches out of push rods from an engine i rebuilt. they work really great and the great part is you can make them the size you need. and it you have a oxy acetelene torch you can temper them to make them stronger. like i said they work awesome.
i made my own push rod checkers out of a few different lengths of push rods. They work but they don't adjust as easily as a boughten ones, But they were free. I just cut the push rod about an inch down from one end then cut another inch off from the long piece and drilled and tapped both ends. I am sure I'm not the first person to do this but i thought i would share.
I love that vertical table Cboy.. great idea..
Always learning...and sharing what I've learned. The Scratch-Built Hot Rod. |
| Recent Garage - Tools posts with photos |
| Currently Active Users Viewing This Thread: 4 (0 members and 4 guests) | |
| Can you help me out? Looking for home made (or modified) tools or garage stuff | toddwallace | Hotrodding Basics | 4 | 05-26-2010 08:57 AM |
| Home made 700r4 transmission tools | 1955Olds | Transmission - Rearend | 2 | 09-10-2009 01:02 AM |
