Thought I would add this one.
36" paper roll cutter. Thought I would practice welding a bit. had some rusty scrap around and thought I may as well put it to use. copper tube for paper holder, 3 pieces of left over t-bar ceiling system with $4 harbor freight blade welded to it, center carb stud to hold down air cleaner guides the tbar down while the carb springs pull it down tight (but not to tight). I have a tape holder there too, so when you pull paper tape will be at edge (ran out of tape). Works great. ![]()
I thought I would go ahead and address table issue.
The table is solid but the legs are not assembled very well and wobbles bad. Un-bolted the wood off the legs and was glad the 3x3x1/16 metal legs were extremely sturdy. had a piece of 3x3x1/16 unistrut in the corner. Cut in half was the exact width of the table ![]() ![]() painted- HF welding mask does work great, thought I would throw that in. ![]() Gona pick up some caster for it soon, may be today. I do get excited when I have time to do this kinda stuff. |
looks great Mr Gm.
Brian |
MRGM is that a Miller Passport in the photos or is it a suitcase welder? If that is the Passport have you ever ran the small one pound bottles of gas on it? And if you have how long do they last? We have a Miller Passport at work and we like the portability of the 110 volt welders like the Miller 140. That is why we chose the passport is because of the portability of it and being able to run it on 110 and 220. I really like the welder but I can't get them to try the 1 pound bottles because they don't think they will last long enough to buy them so we just run flux core in it.
MRGM,
Luv the hand drawn frowney faces and the running commentary. By the way, speaking of frowney faces for you curmudgeons. Did you know it takes over 40 muscles to show a frown...but only 4 to give the finger? (Heard last week on Prairie Home Companion of all places.)
Always learning...and sharing what I've learned. The Scratch-Built Hot Rod. |
I el oh eled
We have a Miller Passport at work and always run bare wire. We had our local supplier make us a special bottle for it.
It is a "60" with one of those no cap tops on it and is filled with #6. It is easy to transport and lasts far longer than messing with those little bottles, and needless to say we dont have the messy fluxcor welds. |
I've made tons of homemade tools. Lots for the hovercrafts that my dad and I built over the years. Plus I'm an industrial mechanic so I've made plenty of SST (special service tools)
Here is one from a hovercraft project, I just stumbled on this video on my computer. The summer after I graduated Highschool (2003) I designed and built a 1/2 scale RC hovercraft, 6' long 5hp garden tiller engine, 30" foam prop I designed and built, etc........ Anyways I've been into wood turning for a long time so I figured why not make a lathe to turn a thrust duct for the hovercraft. I cut 2 30.25" disks with a home made router circle cutter, spaced them apart with 2x4's and had a 1" hole drilled through the center. Then wrapped the disks with 1/8" plywood for the liner of the duct and then wrapped I think 2" foam around that. I then mounted a 1" dowel cantilever style to the work bench. Next I made a treadle lathe and used that to spin the duct and used some drywall sanding screen to turn it down into an airfoil shape. (sanding screen works great for sanding foam btw) Anyway here is a quick video of it. http://www.youtube.com/watch?v=93Qr2PRlKlw And a couple finished pictures of the rc hover, I designed and build pretty much everything but the engine, pulleys and belt. |
I was trying...........
Did it work???????? Do you feel the urge to finish up laying the laminate flooring in my house so I can go out in the garage and work on our beetle project?????? LOL Quote:
No, just a craving to eat lunch meat on the floor in my kitchen....think you were off a little.
| Recent Garage - Tools posts with photos |
| Currently Active Users Viewing This Thread: 2 (0 members and 2 guests) | |
| Can you help me out? Looking for home made (or modified) tools or garage stuff | toddwallace | Hotrodding Basics | 4 | 05-26-2010 08:57 AM |
| Home made 700r4 transmission tools | 1955Olds | Transmission - Rearend | 2 | 09-10-2009 01:02 AM |
