show me your home made tools so I can copy them! - Page 9 - Hot Rod Forum : Hotrodders Bulletin Board
  #121 (permalink)
Old 06-26-2010, 11:10 AM
Duntov's Avatar
Visit the NASCAR Hall of Fame
Originally Posted by 454 Rattler
That goes for all these tools.
I'd rather make it than buy it !!
454 RATTLER
I can identify with that statement and figure it fits a lot of us. I really enjoy using a newly designed tool to produce an improved product; at least for the first few times. I've done it every chance I've had since the Sixties. Right now I'm on a piston/rod handling fixtures kick. Different kinds of rod heaters, different ways to float small end/big end to get more repeatable 1/10 gram readings. Lots of fun.
It's about the only circumstance in which I lose track of time and forget to eat. And then when someone comes along and makes me aware of the time or that a meal has been missed by hours then sometimes I realize at that moment that I am not hungry.
And otherwise I' m almost always hungry..
  #122 (permalink)
Old 06-27-2010, 05:09 AM
deadbodyman's Avatar
Wiki Edits: 11
Man, you got that right..when I'm on a roll ,working on something I wake up,go out and start working ,after a couple hours I realize I missed breakfast but I'll forget about it and keep on working then around noon I realize I need to eat lunch but I'm just not hungry enough to stop,Then my wife comes home so its 5:00 and starts dinner but by then I'm almost done and to dirty to stop,get cleaned up and eat so when starts getting dark (8:00) and I pick up my mess and go inside shower and eat.fall asleep on the couch...I'll put in a 12-13 hr day every day when I'm working on my stuff.but put me on someone elses and I start gaining weight....breakfast, lunch, dinner all on time...
  #123 (permalink)
Old 06-27-2010, 07:45 PM
Duntov's Avatar
home made tools that work
OK,
We have several wonder bars on the wall. They're not all the same.
One has a 5/8ths square hole in it on the flatter end, cut with a dremmel and cut off wheel.
The hole centers back just far enough from the nail pulling fork that you push the fork under the rocker nut and press down on the valve spring. Lay a magnet over the hole, and remove the keepers.
Of course it should go without saying that the cylinder is charged....By the way, a charged hole is the best diagnostic tool I ever discovered. Duntov
  #124 (permalink)
Old 06-28-2010, 04:38 AM
Wiki Edits: 11
Originally Posted by Duntov
OK,
good idea ,I'll hook my wifes up to 12v the next time she wont tell me whats wrong...
  #125 (permalink)
Old 09-07-2010, 06:06 PM
Check your spark plug gaps
Not a tool at all, just thought this was pretty cool, what rearend would be used to make this thing spin the slowest?
http://www.youtube.com/watch?v=VR_m9Jnm_vY
  #126 (permalink)
Old 09-07-2010, 06:25 PM
S10xGN's Avatar
Gotta love a turbo!
Low to mid 2.xx's, fairly common from the mid 1970's through mid 1990's...
Russ
  #127 (permalink)
Old 09-07-2010, 07:01 PM
like a 1979 ford fairmont maybe?
  #128 (permalink)
Old 09-08-2010, 07:54 AM
Im trying to have an idea!
that is so funny
  #129 (permalink)
Old 09-08-2010, 04:13 PM
Think I'll do the same thing, but I'm gonna hook her's up to twelve volt positive and mine up as the ground. That way we'll both get a jolt at the contact area.
  #130 (permalink)
Old 09-08-2010, 04:50 PM
Once I found out that Peugeots had rebuildable tie rod ends I decided to make it my business to do that job myself... not hard...
But then there were the ball joints on the lower ends of the Macpherson struts, which are quite a deal harder and require 'Special Tools' from the factory.
Not my style, so I looked it over and went out seeking materials. I determined that I wouldn't spend any money on this, just use up bits I had or could find for nothing.
First there was a cover that screwed into the socket in the lower control arm. It required a 3-pronged device, so I went to a suspension shop and raided their pile of discarded struts and shock absorbers. I found a piece of tube that fitted neat inside the cover, then another piece that slipped over it. I cut the larger piece so it fitted into the slots on the cover and welded it over the piece that slipped inside, drilled a hole in the other end and I had my tool to remove the cover.
But inside the nut that held the ball onto the taper that's on the bottom of the strut (yeah, they are way different to any other struts!) required something similar in reverse. A piece of hollow tie rod was the right diameter to cut the prongs into and fit over the central section of this nut, I simply welded an old socket onto the other end.
And so I became capable of doing my own ball joints on Peugeot front ends. Cost me a couple of sticks of weld and a bit of running around finding materials.
  #131 (permalink)
Old 09-09-2010, 09:06 PM
MRTS33's Avatar
33 Pontiac 3W Sport Coupe
Love this thread.
  #132 (permalink)
Old 09-13-2010, 07:59 PM
im turning a old laundry room sink in to a parts washer its only like $45 in parts better thin $100 for a new one
  #133 (permalink)
Old 09-13-2010, 08:30 PM
$45?
Around here you just wait for one to turn up at the tip, then get a grille-type shelf from a refrigerator (from the same source) and you're halfway there...
  #134 (permalink)
Old 09-13-2010, 09:13 PM
evolvo's Avatar
Heathen
Maybe this is common knowledge and I just figured it out, or maybe I discovered something! I've been using 3" rolocs for grinding and have noticed that they typically wear out on the outer diameter but still have lots of grit left towards the center. Aha! I take the worn out 3" ones and mount them on a 2" mandrel and use a not so great pair of snips to cut around the circumference. I then have a new working surface and have doubled their life.
Anybody else do this?
  #135 (permalink)
Old 09-19-2010, 09:07 AM
Yep!! At a buck +, any increased life span is a great savings.
Trees
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Can you help me out? Looking for home made (or modified) tools or garage stuff toddwallace Hotrodding Basics 4 05-26-2010 08:57 AM
Home made 700r4 transmission tools 1955Olds Transmission - Rearend 2 09-10-2009 01:02 AM
