Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - show pics of your engines boys!
  #477 (permalink)
Old 11-06-2010, 10:26 AM
adantessr's Avatar
adantessr adantessr is offline
'23 T-Bucket Pickup
Last wiki edit: Troubleshooting ignition Last photo:
Wiki Edits: 3
It won't work
Originally Posted by Bad Rat
Is is Ok to use Roller lifters with a flat tappet cam ? just askin,,,,,,,,,,,
The reason the flat tappet cam will not work with roller lifters is because the cam lobe profile is totally different on roller lifter cams and flat tappet cams , and would change cam timing and dwell drastically , So the short answer is NO . You cannot run roller lifters with a flat tappet cam or vice/versa .
