Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - show pics of your engines boys!
  #196 (permalink)
Old 08-26-2007, 07:11 PM
66GMC's Avatar
66GMC 66GMC is offline
Get in, sit down, hang on
Last journal entry: Cab Mounts
Originally Posted by firestone
Thanks, it took a while to get it done, but I am really happy with how it turned out. That storage unit it is pretty much all I have to work in right now. I live in an apartment building a couple of miles away. By bypass elbow, I assume you are talking about the one that goes from the water pump to the intake manifold, I am not sure where it came from. The shop that installed the engine came up with it. I did a little searching and came up with the following though.
http://www.jegs.com/webapp/wcs/store...56689_-1_10603
Adam
Adam:
Yeah, thanks.
I found the same thing on Summit (made by Earl's)
I was looking at the length of the barbed end with a bit of skepticism, though. Is yours as long as what that appears to be?
Page2171:
I had the same car at age 17 or so.
Same engine, too.
I hadn't heard the term "nailhead" at that age, though.
I bought the car from my uncle, and destroyed it in very short order ... racing a '72 Chevy 1/2 ton with a 350 4bbl.
The car had a rad leak, and at that age ... I drove it as long as the wheels would turn. Guages were something you looked at AFTER seeing the smoke or hearing the noise back then, I guess.
