show pics of your engines boys! - Page 14 - Hot Rod Forum : Hotrodders Bulletin Board
  #196 (permalink)
Old 08-26-2007, 07:11 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Mounts
Originally Posted by firestone
Thanks, it took a while to get it done, but I am really happy with how it turned out. That storage unit it is pretty much all I have to work in right now. I live in an apartment building a couple of miles away. By bypass elbow, I assume you are talking about the one that goes from the water pump to the intake manifold, I am not sure where it came from. The shop that installed the engine came up with it. I did a little searching and came up with the following though.
http://www.jegs.com/webapp/wcs/store...56689_-1_10603
Adam
Adam:
Yeah, thanks.
I found the same thing on Summit (made by Earl's)
I was looking at the length of the barbed end with a bit of skepticism, though. Is yours as long as what that appears to be?
Page2171:
I had the same car at age 17 or so.
Same engine, too.
I hadn't heard the term "nailhead" at that age, though.
I bought the car from my uncle, and destroyed it in very short order ... racing a '72 Chevy 1/2 ton with a 350 4bbl.
The car had a rad leak, and at that age ... I drove it as long as the wheels would turn. Guages were something you looked at AFTER seeing the smoke or hearing the noise back then, I guess.
  #197 (permalink)
Old 08-26-2007, 07:21 PM
Brian_B's Avatar
Lost in the 50s!
Last journal entry: time to start body work
Originally Posted by page2171
I probably shouldn't be posting this. My engine is not nearly as clean and nice looking as everyone else's so far. On the other hand, you can't get too much cooler than a Nailhead. So, here it is...a 401 Nailhead in my 62 Buick Electra.
I am going to ask a question that may get me shot, but...
Why do they call it a nailhead?
I have never seen one in person. I am faimiar with ford flatheads and Y-blocks.
  #198 (permalink)
Old 08-26-2007, 08:47 PM
firestone's Avatar
http://teamrfc.gospelcom.net
I think the one on my car is as long as the ones in the summit and Jegs catalog. If you look really closely, you can kind of see where the end of the fitting goes to in the tube on the way to the water pump. The tube seems to be perfectly straight and then makes a abrupt turn to the connection to the water pump. It looks to me like there is not very much space between where the fitting ends and the water pump starts. I have a long pump so that gives me a little more room to allow for the longer fitting. I don't know if it would work with a short pump or not.
Also, Brian, I would like to pretend like I know what a nail head is also and just wait for the answer, but I must confess I dont know either.
Adam
  #199 (permalink)
Old 08-26-2007, 09:05 PM
JWO Racing's Avatar
"Winning heals all wounds"
355 sbc in a stock car
[IMG][/IMG]
  #200 (permalink)
Old 08-26-2007, 09:45 PM
From what I understand they got the name Nailhead because with the valve covers off the valves look like nails sticking up because the valves are vertical not angled like most engines.
  #201 (permalink)
Old 08-26-2007, 09:48 PM
Brian_B's Avatar
Lost in the 50s!
OK..... Can't say that I have ever seen a picture like that either.
That is an interesting design.
  #202 (permalink)
Old 08-27-2007, 04:41 AM
Only a 5lt TPI in my all steel 35 Chevy phaeton
  #203 (permalink)
Old 09-05-2007, 06:16 PM
Turbonoma's Avatar
"Gettin High On Boost"
Last journal entry: More setbacks
Here's my sleeper
It's a turbocharged 4.3 vortec fully balanced/blueprinted,p&p heads sitting in my 98 ext.cab sonoma, making about 350hp.
  #204 (permalink)
Old 09-05-2007, 09:30 PM
TurboS10's Avatar
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
Very cool. What are you using for engine managment?
  #205 (permalink)
Old 09-06-2007, 05:24 PM
Here's my engine:
1980 Chevrolet 350 with 4-bolt mains.
Edelbrock performer 64 cc heads
Edelbrock performer plus camshaft
Edelbrock performer intake
Rochester Quadrajet carb
Summit headers
This picture is from 2002. I pulled the engine out and cleaned it up (picture taken prior to clean up)
This summer I decided to modify it a bit. Out it goes again.
Stripped down to the block, oil pump and crank.
Edelbrock performer heads 64cc, and Edelbrock performer plus camshaft installed.
Overhauled Quadrajet with 0.73 primary jets and 42 main metering rods. Stayed on the rich side just to make sure. I'll try 46 rods soon.
Homemade Ram Air.
  #206 (permalink)
Old 09-06-2007, 06:40 PM
Turbonoma's Avatar
I'm using TunerCat and MXScan. I'll be installing a converted Edelbrock 2114 intake with 65# injectors soon.
  #207 (permalink)
Old 09-08-2007, 02:23 AM
my 289
Ses a cute little thang
  #208 (permalink)
Old 09-09-2007, 07:48 AM
Vortech 4.3's Avatar
jack of all trades
97 S10. 4.3, stock bottom end (for now), cam, ported heads, 2114, 10+ psi boost, powerstoke intercooler, tuning, etc, etc, etc. est over 400 hp.
these are old pics, it better now.
  #209 (permalink)
Old 09-09-2007, 02:55 PM
pontiacjosh's Avatar
84 stroked ss
Last journal entry: exhaust
385 stroker
http://i67.photobucket.com/albums/h3...h/100_1050.jpg
  #210 (permalink)
Old 09-10-2007, 12:00 AM
orn orn is offline
Here is mine.
A 300 hp small journal 327 with Th 350 auto in a –41 Buick Sedanette.
ID:	24103   Click image for larger version
re-arrange pics in photo album ChevelleSS_LS6 Hotrodders Site Suggestions and Help 7 01-25-2013 07:54 PM
New Classic Car TV show foggy Hotrodders' Lounge 44 01-14-2013 09:58 PM
Pics of a car show smoke Hotrodders' Lounge 1 03-05-2006 04:43 PM
6 pics from AllChevy/Camaro show, Issaquah WA 7-17-5 bullheimer Hotrodders' Lounge 1 07-17-2005 11:30 PM
Quincy,IL car show pics TooMany2count Hotrodders' Lounge 0 12-15-2003 06:52 AM
