show pics of your engines boys! - Page 15 - Hot Rod Forum : Hotrodders Bulletin Board
  #211 (permalink)
Old 09-10-2007, 03:43 PM
Last journal entry: Free tires
Just got it back Saturday.
ID:	24119   Click image for larger version
ID:	24120   Click image for larger version
ID:	24121   Click image for larger version
ID:	24122   Click image for larger version
  #212 (permalink)
Old 09-10-2007, 07:56 PM
84 Monte Carlo's Avatar
Auto Tech
Last journal entry: this car is for sale
all motor and can't show a pic
  #213 (permalink)
Old 09-11-2007, 09:41 PM
Wiki Edits: 31
Ok I guess it's time for an update pic. Ford 200 I6, now fully custom/ rebuilt. Turbocharger, .030 flat top pistions, chrome moly rings, 0 decked, 1979 cylinder head, 8.8:1 compression holley 2300 2bbl, full roller rockers, billit dual roller timing set. 224/224 .495 lift cam. still finishing up. should have around 300- 320 hp at the crank when done.
  #214 (permalink)
Old 09-28-2007, 10:54 AM
re: show pics of your engines boys!
It's starting to look like a small block instead of a pile of parts.
350 4-bolt, forged crank, 10:1 comp., GM iron 041 heads and Q-jet by SMI
  #215 (permalink)
Old 11-26-2007, 07:51 AM
SnottyAust's Avatar
GTS Monaro Coupe 406
Check out this thread by me for pics of my engine and what im doing with it.
http://forums.ogn.com.au/showthread.php?t=44476
  #216 (permalink)
Old 11-27-2007, 08:16 AM
triathlonx13's Avatar
No that's a beautiful Engine !!!!
  #217 (permalink)
Old 11-27-2007, 08:24 AM
Pontiac 461
Here is a pic of my Pontiac 461 stroker motor
ID:	25820   Click image for larger version
  #218 (permalink)
Old 11-27-2007, 08:25 AM
TMF TMF is offline
Very nice! They are a work of art before being installed.
  #219 (permalink)
Old 11-27-2007, 06:35 PM
Here's my 2-bolt 355 I've been working on for a little while. It's got flat top hyperutectic pistons, 9.75:1 cr, EQ Lightning 180cc cylinder heads w/ 2.02/1.6" valves, Comp cams hydraulic roller cam w/ .502/.51" lift and duration of 276/282. Edelbrock performer RPM intake manifold, edelbrock tall valve covers, scorpion full roller rockers. Still shopping for a few things such as water pump, carb, air filter, and a tranny! Eventually going into an earlier model s10 (mid 80's-early 90's). What do you think?
  #220 (permalink)
Old 11-28-2007, 07:47 AM
lakeroadster's Avatar
Hot Rods are Built, not Bought
Last journal entry: Lakeroadster's '31 Model A Tudor
Bowtie Powered '31 Model A Tudor
5.0 H.O. Powered '27 Model T Roadster Pickup
Name:	Model A 350 Engine 50%.jpg
ID:	25857   Click image for larger version
Name:	27 RPU Motor.jpg
  #221 (permalink)
Old 11-28-2007, 11:18 AM
11echo's Avatar
Old Guys Rule!...EVERYTHING!
  #222 (permalink)
Old 12-11-2007, 07:33 PM
biggeazy-e's Avatar
custom driveshaft is on the way remote quad turbo
  #223 (permalink)
Old 12-11-2007, 07:59 PM
Yes! you truly are the man. The engine looks familiar. Im putting one on a shopping cart.
  #224 (permalink)
Old 12-11-2007, 08:00 PM
Last journal entry: 63 split window Corvette RESTOROD
from this....350 cu in
to this....383 stroker with EFI
my first project car......took a little over 15 months to go from the top photo to the bottom photo....did a full frame off of the car. Added rack and pinion steering to the front along with coil over shocks and disc brakes as well as a Ford 9" rear with 4 link, panhard bar, coil overs and disc brakes!
more photos from beginning to now..
http://public.fotki.com/htmiata/1960_corvette/
  #225 (permalink)
Old 12-11-2007, 10:23 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
LOL!
That reminds me of my old Tempo!
You'll be tracking your E.T.'s with a calendar!
re-arrange pics in photo album ChevelleSS_LS6 Hotrodders Site Suggestions and Help 7 01-25-2013 08:54 PM
New Classic Car TV show foggy Hotrodders' Lounge 44 01-14-2013 10:58 PM
Pics of a car show smoke Hotrodders' Lounge 1 03-05-2006 05:43 PM
6 pics from AllChevy/Camaro show, Issaquah WA 7-17-5 bullheimer Hotrodders' Lounge 1 07-18-2005 12:30 AM
Quincy,IL car show pics TooMany2count Hotrodders' Lounge 0 12-15-2003 07:52 AM
