show pics of your engines boys! - Page 19 - Hot Rod Forum : Hotrodders Bulletin Board
  #271 (permalink)
Old 04-14-2008, 08:24 PM
biggeazy-e's Avatar
dirty girl......
was in my other, other project (82 Chevy Caprice Classic 2 Door), hopefully within the week will be in my other, other, other project (85 Chevy Caprice Classic Landau 2 Door)... need to strip the paint on the engine, a few new gaskets, clean up the chrome, decide on a new color (black car, probably just go with black for the engine too??..), and re-install...
  #272 (permalink)
Old 04-15-2008, 07:25 AM
Double_v23's Avatar
Horsepower Enthusiast
Last journal entry: Finished BMOD001FH
Here is one that is a little different from what you might normally see on here.
It is a Wissota Midwest Mod engine (B mod) which is very restricted, however these motors will get 375 HP and 400 Ft/lbs out of a 2 barrel holley, 9.5:1 compression, Hydraulic Cam, and large chamber heads with 1.94 1.50 valves. No Port work, no polishing, no grinding, no coatings of any kind. Just time tested and proven machine work and assembly. You can't even use aftermarket cranks and rods. All GM. This one is a 358 CI SBC. And you can buy it today only for 5,000 bucks...just kidding this one is already sold.
ID:	29276   Click image for larger version
  #273 (permalink)
Old 06-05-2008, 09:56 AM
gearhead81's Avatar
Custom Built
needs washed.
  #274 (permalink)
Old 06-05-2008, 11:18 AM
solidaxel's Avatar
Last journal entry: Project garage complete!
At what RPM does it develope 400#ft?
  #275 (permalink)
Old 06-05-2008, 12:56 PM
Double_v23's Avatar
That particular one was not dyno'd but similar ones have gotten those numbers. I believe the torque peaks fairly high, like 5500 RPM or so. We run them up in the 7500-8000 range. but 5500 off the corners where you need the torque.
  #276 (permalink)
Old 06-05-2008, 01:27 PM
cope's Avatar
my solid roller 355 thats in my 75 camaro
and my mopar 366 in my 75 dodge swb 4x4
  #277 (permalink)
Old 06-05-2008, 01:38 PM
Irelands child's Avatar
Update from my 7/28/06 posting:
The painted body is on the chassis, the wiring is about 30% done, upholstery waiting to go in and with completion, assuming no problems, by late summer .
Dave W
Irelands child
  #278 (permalink)
Old 06-05-2008, 01:42 PM
Double_v23's Avatar
How do you like that Predator Carb?
  #279 (permalink)
Old 06-05-2008, 02:04 PM
cope's Avatar
i think it kicks a*s but i onley use it at the track on the street i use a diffent carb if u ran it on the street u would just foul plugs like a **** its onley good for WOT
  #280 (permalink)
Old 06-05-2008, 02:10 PM
Double_v23's Avatar
That is what I thought, I was also wondering what rockers you were running, it looks like those valve covers are pretty short for roller rockers or anything.
  #281 (permalink)
Old 06-05-2008, 02:30 PM
cope's Avatar
im just running your everday 1.5 aluminum roller rockers there the tall milodon covers with a really thick cork gasket and a normal cork felpo on top of that even with a 555. lift cam they still clear the cover.
  #282 (permalink)
Old 06-17-2008, 01:07 PM
312 Ford in a REAL BEAUTY of a T Bird. You might see this one later on...
  #283 (permalink)
Old 06-18-2008, 06:52 AM
65 Imp SS's Avatar
Here is mine
  #284 (permalink)
Old 06-29-2008, 09:54 AM
Here is mine: 4 bolt main 454 punched to 496, Edelbrock #60559 rectangular port aluminum heads, solid 652 lift cam, solid COMP Endura lifters, roller rocks,10.5 compression, Chuck Nuytenn built 1050 Dominator. Should be a terror!!!
  #285 (permalink)
Old 07-04-2008, 10:28 PM
72 grabber 51F-1 65 chevystang
here is the 390 in my 69 F-100. It has an edelbrock performer rpm intake, holley carb, mild cam, headers, chrome valve covers
here is the 351w in dads tr7. It has an aluminum inatke holley carb headers and cam
here is the old 283 that was in the 51. It had no compression so we pulled it out.
here is the 350 that is going back in. We are going to put the valve covers and intake off the 283 on it when its bolted in
these are all my nice engines
re-arrange pics in photo album ChevelleSS_LS6 Hotrodders Site Suggestions and Help 7 01-25-2013 07:54 PM
New Classic Car TV show foggy Hotrodders' Lounge 44 01-14-2013 09:58 PM
Pics of a car show smoke Hotrodders' Lounge 1 03-05-2006 04:43 PM
6 pics from AllChevy/Camaro show, Issaquah WA 7-17-5 bullheimer Hotrodders' Lounge 1 07-17-2005 11:30 PM
Quincy,IL car show pics TooMany2count Hotrodders' Lounge 0 12-15-2003 06:52 AM
