show pics of your engines boys! - Page 29 - Hot Rod Forum : Hotrodders Bulletin Board
  #421 (permalink)
Old 02-25-2009, 07:34 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
good sounding motor wmhjr.
  #422 (permalink)
Old 02-25-2009, 07:42 PM
A couple pics
Pontiac 400 block, 3" mains, 4.25" forged stroker crank, 4340 forged ultralight rods, Ross pistons (about 10.8 compression), Custom grind roller cam, .660 lift, solid roller lifters, stainless big bearing 1.65 roller rockers, KRE Aluminum heads (320cfm port by SD Performance), 4 bolt billet caps, custom built holley @ just about 1000cfm, RobbMC mechanical 1100hp fuel pump, Port matched T2 intake. Pro Billet distributor and MSD-6AL2 ignition. Ends up around 462ci. I really think this will be fun to drive. Valve covers still have to be polished.
  #423 (permalink)
Old 02-25-2009, 07:50 PM
eloc431962's Avatar
Wiki Edits: 37
That really looks good.no doubt it will be fun to drive just imagine drop the top and really listen to the motor.yep lots of fun. cole
  #424 (permalink)
Old 02-25-2009, 07:54 PM
Especially when I have the opportunity to open the electric cutouts.....
  #425 (permalink)
Old 02-25-2009, 08:49 PM
solidaxel's Avatar
Last journal entry: Project garage complete!
[QUOTE=hotrod937]Why it became a table.
[/QUOTE
......... Nice Picture Window !!!!!!!
  #426 (permalink)
Old 02-26-2009, 03:27 PM
ortamenxs's Avatar
Avoid the Gremlins.
This thing had a hard life starting with a vette from the 60s, then being pulled used here and there, built, and rebuilt. Until I got her and gave her a permanent home. I'll slap her as an attachment, because for whatever reason the scale is messed up if I post it in this message.
Older pic before the new headers and wire clean up. I have to find my camera.
Last edited by ortamenxs; 02-26-2009 at 03:28 PM. Reason: I still can't spelllll stuf.
  #427 (permalink)
Old 02-26-2009, 07:39 PM
Originally Posted by 428ho
400 Pontiac. Kind of a hybrid mix of Ram Air parts.
RA-V 4 bolt block, SD 455 Rods, RA-IV cam, RA-III heads, mallory, edlebrock with Carter 650's, headman headers.
Pics are when I first put it in and after several years of flogging it and then storage.
She's on the mend now to her former glory.
i love bop's never finshed my dual quad pontiac 400...
  #428 (permalink)
Old 04-02-2009, 04:24 PM
Joe G's Avatar
These engines aren't mine per se, but I guess possession is 9/10's of the law....
These belong to my customers:
327 with custom Hilborn EFI in a Dearborn Deuce - It's going to the dyno next week.
Blown 460 - Very mild cam, low compression heads and underdriven blower, and it still makes 600 hp/600 ft-lbs on the engine dyno.
Chrysler 354 with 3 Rochesters. In a steel '32 Ford Victoria.
  #429 (permalink)
Old 04-03-2009, 06:43 AM
Love that green MFI.
  #430 (permalink)
Old 04-03-2009, 07:56 AM
jchav62's Avatar
Registered Loser
Mine...
The engine in my '62 c10...
1964 327, ss motor, 300hp
10.5:1 CR, slightly larger then stock cam (224/224, Summit)
1.94 camel back heads
Edelbrock RPM Performer intake
Edelbrock AVS T.S. 650cfm
Heddman Hedders
Virgin motor, around 70,000 original miles....still runs very strong .
ID:	37375   Click image for larger version
  #431 (permalink)
Old 04-03-2009, 10:52 AM
jchav62's Avatar
Registered Loser
Another...
355 going in a '65 c10 Short/Fleet...
Edelbrock performer intake
Flat tops
PAWS dual duration cam
Edelbrock 600cfm
Stock ramhorn ex. manifolds
ID:	37377   Click image for larger version
ID:	37378   Click image for larger version
  #432 (permalink)
Old 05-08-2009, 10:45 PM
Roadkill58's Avatar
Rust Never Sleeps
Last journal entry: Step notch
Tpi
I think I put it in the wrong end.
  #433 (permalink)
Old 05-09-2009, 02:51 PM
yevgenievich's Avatar
Last journal entry: pictures, try#2
I just put my TPI into storage and put ls1 into my Trans Am and got 468 bbc to go into my Camaro
  #434 (permalink)
Old 07-17-2009, 06:05 AM
My68Vette's Avatar
I thought I would bump this by adding mine... SBC 355, 452hp, 440tq (Dyno).. Its now installed in my 68 Vette.. I need a new rear gear but with the stock 3.08 I still have to back pedal it when I mash it to the floor..
  #435 (permalink)
Old 07-17-2009, 09:53 AM
Wiki Edits: 49
Sitting in my Deuce frame ready for accessories. 1955 Chrysler C-300 331 cu. in. Hemi. Stock - 300 hp @ 8.5:1 compression and around 350 ft. lb. torque. This one has been tweaked a little. More than enough motor for a Deuce and best of all its not a SBC.
re-arrange pics in photo album ChevelleSS_LS6 Hotrodders Site Suggestions and Help 7 01-25-2013 07:54 PM
New Classic Car TV show foggy Hotrodders' Lounge 44 01-14-2013 09:58 PM
Pics of a car show smoke Hotrodders' Lounge 1 03-05-2006 04:43 PM
6 pics from AllChevy/Camaro show, Issaquah WA 7-17-5 bullheimer Hotrodders' Lounge 1 07-17-2005 11:30 PM
Quincy,IL car show pics TooMany2count Hotrodders' Lounge 0 12-15-2003 06:52 AM
