show pics of your engines boys! - Page 6 - Hot Rod Forum : Hotrodders Bulletin Board
  #76 (permalink)
Old 07-26-2006, 09:08 PM
inquiring_mind2's Avatar
a shade tree mechanic
here is my engine. I worked on it all winter with the help of alot of people on here. THANKS
  #77 (permalink)
Old 07-27-2006, 07:40 AM
fat40's Avatar
My pic
Here is a pic of my 383 stroker that in my 40 Ford Coupe, just a mere 450 H.P what a kick . It sure makes this old guys life fun .
Fat 40
Name:	Sid Mtr A.JPG
  #78 (permalink)
Old 07-27-2006, 06:16 PM
327 in a rusty Impala demolition derby car. Runs better than it looks!
  #79 (permalink)
Old 07-28-2006, 10:50 AM
Big Block Z28
468" in 70 Z28
ID:	13709   Click image for larger version
  #80 (permalink)
Old 07-28-2006, 12:38 PM
Irelands child's Avatar
My FORD engine
Ford 5.0 crate motor
GT 40P heads
Sanderson Headers
Crane 1.7 roller rockers
SVO E303 Cam
600 CFM Edelbrock Performer
Performer RPM Intake
MSD Billet Distributor/ignition
Stewart NASCAR water pump
Street and Performance auminum brackets
And yes, in this photo, the valve covers are on the wrong sides. Guess it must have been a bad day - but they weren't bolted down yet.
  #81 (permalink)
Old 07-29-2006, 12:51 AM
Sledgehammer
302 Ford in my 91 E-150 Van,
600 Edelbrock Performer carb
Edelbrock Performer Intake
Accel billet dizzy
Accel supercoil
MSD 6AL Ignition
Ford Motorsports Headers
Some Edelbrock shiny stuff
Holley electric fuel pump
351 in the works...
ID:	13716   Click image for larger version
  #82 (permalink)
Old 07-29-2006, 03:47 PM
Stu Cool's Avatar
Make it cool, low and drivable
Last journal entry: Adding Cold Air Intake
LS1 in 53 Studebaker Engine Pics
This is the 2000 LS1 that I just finished installing in my '53 Studebaker. It has an LS6 intake and valve springs, Corvette drive by wire throttle, and modified Sanderson headers with true dual exhaust. Its backed up by a 4L60E 4 spd OD automatic with a Yank 2800 stall converter, then an 8 inch Ford rear axle with true trac and 3.80 gears.
Name:	Ls1 Project Finished 004.jpg
ID:	13721   Click image for larger version
Name:	Ls1 Project Finished 001.jpg
ID:	13722   Click image for larger version
Name:	Ls1 Project Finished 003.jpg
  #83 (permalink)
Old 07-29-2006, 03:48 PM
Nothing special... but I love her anyways,
My first and only engine I've built thus far, shes been going for a few years and built her when I was 17. Unfortunately I had no help and ended up assembling it from bottom up a handful of times before getting it right.
Anyways I'm happy with it.
-GM Crate 350 block
-Cast bottom end
-#450 heads, 60cc, 2.02/1.6, hand ported by yours truly
-1.6r roller tip comp mangum rockers
-10:1 cr
-Comp XE274, 230/236@0.50, .522/.522 (corrected) lift
-Edelbrock performer RPM intake
-Holley 4150DP 750cfm carb (modified for racing)
-Hedman 1 3/8" shorties
Sitting between the framerails of a 1984 S-10 short cab stripper truck. Used for street/strip fun. Also my first vehicle I purchased at age 11 :-)
  #84 (permalink)
Old 07-30-2006, 08:22 PM
Heres mine
ID:	13762   Click image for larger version
  #85 (permalink)
Old 07-30-2006, 09:05 PM
onebadmerc's Avatar
I need a bucket of arc sparks
Here is a picture of my 289 in my 66 Comet
  #86 (permalink)
Old 07-31-2006, 02:05 AM
Where's my Sawzall?
Last wiki edit: Window removal and installation
Last journal entry: More progress...
Wiki Edits: 2
Kustomsledd 472 Caddy pics...
are in my photo album here. Partial disassembly to refresh gaskets and repaint engine/trans. And there's a video of me running the 472 on the garage floor (read-open heads )in the POTW section, see lower left of the main page here.
  #87 (permalink)
Old 08-01-2006, 01:18 AM
barbiekiller's Avatar
Front wheel drive= pain in a**
boys?....Boys!?!?! sbc 350 going into a 1970 gmc.
ha....boys
  #88 (permalink)
Old 08-01-2006, 02:17 AM
Ortie666's Avatar
I smell Clutch!
3.2L Bored&Stroked chevy 6-60... about hotrod as a V6 will get with a custom aluminum intake manafold, the power is estimated at about 200-225 N/A with a propper induction system, and about 300 and some if it were to have 3100 heads/intake and supercharger witch is amazing in a car that weighs 1900lbs
ID:	13807   Click image for larger version
  #89 (permalink)
Old 08-01-2006, 04:53 PM
schnitz's Avatar
Last wiki edit: Building a new shop
Last journal entry: Christmas 2008 came early!!!
Wiki Edits: 54
While definately nothing hot as of yet (I'm just going warm anyway-- Hey it's mine, so I can build what I want...), here's my 305. It's currently sitting in my '78 Monte Carlo, and it'll head back in after I try to squeeze 1 H.P. per cubic inch. Or blow up trying. As it sits, it has not been ran in 11 1/2 years, and last ran 8 psi at near WOT @ minus 20* with 20-50W oil in the pan. On the plus side, it never knocked and can still be turned by a socket on the crank pulley.
In a while, Chet.
  #90 (permalink)
Old 08-01-2006, 07:03 PM
oops! I toopk it out for a rebuild. 94 5.8 fi roller stocker.
re-arrange pics in photo album ChevelleSS_LS6 Hotrodders Site Suggestions and Help 7 01-25-2013 07:54 PM
New Classic Car TV show foggy Hotrodders' Lounge 44 01-14-2013 09:58 PM
Pics of a car show smoke Hotrodders' Lounge 1 03-05-2006 04:43 PM
6 pics from AllChevy/Camaro show, Issaquah WA 7-17-5 bullheimer Hotrodders' Lounge 1 07-17-2005 11:30 PM
Quincy,IL car show pics TooMany2count Hotrodders' Lounge 0 12-15-2003 06:52 AM
