Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - show pics of your engines boys!
  #266 (permalink)
Old 02-24-2008, 08:51 AM
kookykrispy's Avatar
kookykrispy kookykrispy is offline
hot rod freak
This is the big blown 463 pontiac I'm in the process of assembling for my '67 GTO, just mocked up for now.
Shortblock: '68 428 block, bored .065 over, filled with hard-block up to the bottom of the freeze plugs, all new internals eagle 455 crank & forged steel rods, J&E flat top forged pistons, Total seal TNT rings, billet 4 bolt main caps, Clevite 77 bearings, all work done @ Accurate Engines in Kirkland, WA
Heads: 7m5 heads 114cc chambers, with 2.11/1.77 stainless valves, exhaust crossovers filled, ARP head & main studs, butler head gaskets, 8.3:1 static compression ratio
Camshaft: SUM-K2802 282/292 adv duration, 224/234 duration @ .050, .512/.537 lift with 1.65 harland sharp rockers, crane dual valvesprings
Induction: GMC 6-71 blower, old weiand front & rear covers, BDS intake, 3" drive, dual holley 750 vac secondary carbs
Misc: Meziere water pump, Canton oil pan, homemade crank scraper, Melling H/V oil pump, M/T valve covers, hooker super comp headers, flat Tempest hood cut for blower (don't worry, I didn't cut the GTO hood)
I also have a set of fully ported 6x-4 heads (93cc chamber, yeilds about 9.5:1 C.R.) and a performer RPM intake so I swap to a single 4bbl carb and the stock GTO hood. This way I can either run blown or Naturally aspirated, depending on what I'm doing with the car, the swap can be done in just a few hours.
