Look in the middle of the passenger side of the block, it will be a vertical number saying something like D1VE, C8VE, D7VE, etc..... If the exhaust manifold is on it you probably won't see it. Ok that wasn't a intake number, my bad, but i knew it wasn't a block casting number. I heard of that number before but needed some refreshing when you put a picture of it up. About five or six months ago I sold two 460 timing covers and one of them had that exact same number on it. That engine came out of a 77 F250, had a D1VE block casting number, D3VE heads, D6TE rods and a C8SE timing cover.
BTW if you are looking at sb Ford casting numbers they will be down by the starter. A FE engine should be on the drivers side by the oil filter and a 429-460 will be in the middle of the block on the passenger side. Register now (free) or login to remove ads |
#17
I don't know about the other manufacturers but Ford used the same timing cover for years, that's why that isn't a good source for dating. I think they only made 2 FE timing covers ( maybe 3, the very first ones may have been stamped steel), aluminum and with only a couple of #'s. The same is true of most other engines,SB and BB.
| Similar Threads for: "Block ID" | ||||
| Small Block Vs. Big Block | rhanshaw | Engine | 30 | 12-26-2007 02:02 PM |
| Verify a 351w block. | Not2psycho | Engine | 3 | 05-27-2007 04:23 PM |
| Big block questions, help please??? | 67 sleeper | Engine | 20 | 05-15-2007 04:24 PM |
| Small Block to Big block pullies | WakBordr7387 | Hotrodding Basics | 5 | 01-30-2007 12:35 AM |
| SBC Block I.D. Casting# confusion | 1Fast65Elky | Engine | 2 | 10-13-2004 07:44 PM |
