Thanks. Its A Rec Port Intake Any Way So I Don't Think It Would Work Any Way. Any Suggestions On What I Should Buy All That Is Done To My Big Block Is Its 30 Over.
#17
eldebrock performer or performer-RPM seems to be a good one what is the truck used for? 4x4 or 2wd street
is the rest of the motor stock? i.e. cam or headers? |
#18
2 wheal drive 3in pipes headers stock cam and heads but want to get some sound and pep
#19
id go Performer-RPM then itll give you room for a little improvement later
#20
that's what i want bit by bit . hay do roller rockers make a big difference?
#21
id save that for later, unless just maybee
comp cams 1:72 roller tip will give you a touch more lift on that stock cam |
| Similar Threads for: "big block hellp" | ||||
| Big block chevy into a 91 S-10?? | 12second6 | General Rodding Tech | 11 | 04-28-2009 06:43 PM |
| Big Block 82 Pontiac Gran Prix | william27103 | Engine | 3 | 03-30-2009 12:50 PM |
| Ford Big block 4 spd bellhousing | bigblocktorino | Transmission - Rearend | 3 | 10-05-2006 03:56 AM |
| Small Block Vs. Big Block | bfrett123 | Engine | 3 | 10-14-2004 05:27 PM |
| big block or small block ford? | stangfiend | Engine | 3 | 12-10-2002 09:55 AM |
