1999 Surburban Vortec 350 need build help
To start I have a 99 Chevy Suburban 211K miles that had a cracked exh. valve seat with minor coolant loss and I decided to replace the heads with new GM Performance stock heads. During which I also figured I would re-seal the engine with all new gaskets, timing cover, etc. When I pulled the oil pan I noticed bearing issues and decided to rebuild. So the engine's out and waiting. I am not looking to run 6500 RPM's and drag race. I don't want to worry about it when I stomp it to pass though. It will be daily driven and pull a moderate bass boat or trailer. Camping and fishing I do alot of. I would like to pull off a red light and make the other guy wonder what I had. I want this engine built right and reliable to take long trips in. This is the reasoning behind not going beyond .040 bore if needed. Fuel ecomony doesn't matter much as long as we don't hit 8mpg highway. I am looking to get another 200K out of this fine SUV and still get a very obvious performance increase.
This is what I have: Stock L31 Vortec MPI engine never touched New Stock GMPP Vortec heads New stock oil pump to be installed GMPP Timing Set stock style chain and gears 3.73 G80 Posi-Trac rear end Stock Torque Converter and 4L60-E trans What I would like to have: Significant torque increase with some HP Probably will put headers on now and upgrade exhaust later. Crank, cam, bearings, and maybe lifters all need replacing pistons, bore, and rods look good but would consider boring .030 or .040 machine shop will likely install cam bearings I am looking for suggestions on what cam and crank to go back with. Can I stroke to 383 without a program? How would the computer act with a .470 cam and .040 over bore without stroking? Would I be able to hear a little rough idle to sound good? Would 1-5/8 or 1-1/2 shorty headers hurt my low end torque? If I was to be suggested to go higher lift and require milling guides and such, what computer should I go with. I am hoping someone has had a sucessful combination such as this. I searched and couldn't find anything similar to what I'm looking for. Thanks for the help in advance. Brian Register now (free) or login to remove ads |
| Similar Threads for: "1999 Surburban Vortec 350 need build help" | ||||
| ARE 305 and 350 VORTEC HEADS SAME | badriand | Engine | 39 | 04-06-2011 08:40 AM |
| 350 engine build | BLUE82 | Introduce Yourself | 3 | 12-01-2006 08:17 PM |
| 96 chevy 305 vortec heads on 350 block | badriand | Engine | 6 | 02-20-2006 07:45 AM |
| 350 tbi build up | jackfrost51 | Engine | 3 | 02-01-2003 02:39 PM |
| 350 Chevy build | Streetmachine | Engine | 11 | 12-10-2001 04:31 PM |
