355 block... small crack
![]() ![]() i have this crack on the passenger side of the block where the starter bolts up too... the crack goes down about 1/8in... i just saw after cleaning the block ill be taking it to the machine shop to get it hot tanked and a hone job so i was wondering if the machine shop could fix this and if not does it really pose a danger as in the starter not being secured properly... Register now (free) or login to remove ads |
Unfortunately this is a common problem. Most of the time it's because the rear starter brace has been removed & or the wrong mounting bolts are used that don't have the knurled shank. The crack isn't easy to fix either. I seen people weld studs in, weld the block and the easier fix is to use a long stud or bolt that will reach all the way thru with a nut on top. The top isn't flat tho' so a bevel nut was used, may have been in a post by (OldBogie). There was a link to the type of nut needed. Try doing a search for (starter crack) (mount crack) etc...
| Similar Threads for: "355 block... small crack" | ||||
| big block or small block chevy | 69YENKONOVA | Engine | 81 | 05-13-2010 07:26 AM |
| how strong is a 350 small block | ChevyVan | Engine | 18 | 01-04-2007 11:27 PM |
| 400 small block idling problems | 19nova72 | Engine | 15 | 04-16-2006 02:53 PM |
| Small Block Vs. Big Block | bfrett123 | Engine | 3 | 10-14-2004 05:27 PM |
| big block or small block ford? | stangfiend | Engine | 3 | 12-10-2002 09:55 AM |
