0-80555c 4175 Univ 650 Cfm Dichromate
Hey guys i got this carb for next to nothing 0-80555C 4175 UNIV 650 CFM DICHROMATE . Whats your thoughts on dropping er on a 350 to 375 horse 350ci.. Google doesnt come up with much.
thanks Register now (free) or login to remove ads |
Should work fine. It's a SpreadBore similar to a QuadraJet.
http://store.summitracing.com/partd...15&autoview=sku |
I don`t know if they are like the older spread bore holley`s. if they are I`d rather have a Quadrajet. Why is due to you can only use a stud on the rear bolts and it`s a PITA to get the nut in because the rear bowl is right on top of it. Next I hated it don`t have a adjustable float, you gotta take the bowls off to adjust the floats and if you don`t get it right off it comes again until of course, you ending up breaking the gasket or it`s too compressed to seal anymore. When it needs a rebuild you gotta order a kit that costs $80 bucks as it`s the only kit they have. I found a company called AED that had a kit for around $30. After a while, I got tired of the hassle of the holley`s short comings so I went back to a Quadrajet.
| Similar Threads for: "0-80555c 4175 Univ 650 Cfm Dichromate" | ||||
| Holley 6425 650 CFM 2 barrel | lluciano77 | Engine | 15 | 01-28-2011 11:26 AM |
| 650 cfm for a 454 | redneck_9018 | Engine | 13 | 01-21-2009 12:59 AM |
| 650 cfm mainbody on a 750 cfm baseplate? | darkostoj | Engine | 5 | 09-05-2008 07:38 AM |
| Is 650 cfm enough for this combo? | Mad Maggot | Engine | 9 | 07-11-2005 10:55 PM |
| 600cfm or 650 cfm | Slant3 | Engine | 4 | 05-18-2004 09:48 PM |
