Old 05-07-2009, 10:54 PM
mattmar's Avatar
mattmar mattmar is offline
66 ford mustang head identification
hey fellas i have a 66 mustang with the 289 sb. i am trying to identify the cylinderheads under the valve cover it is stamped 302. along with 2j14 and b23 i know this is not much info to go on. but im guessing they are off a 302.but wondering if the other numbers and letters there could possibly tell me more. any info is greatly appreciated thanks in advance!
Old 05-07-2009, 11:45 PM
powerrodsmike's Avatar
powerrodsmike powerrodsmike is offline
Last wiki edit: Make a fiberglass fan shroud
Last journal entry: Next.. ..Bagging the king B (barge)
Wiki Edits: 161
If it says 302 then that's what it is, the actual casting number that would tell you the application is located under the head, by one of the pushrod holes. You can only see it when the intake is off, with a mirror. The casting number is more important than the date code, as there were differences between the combustion chambers and ports.
You can tell a little bit from what type of rocker setups it has, the pedestal rockers were from later motors.
check this website out, it has some info about where to look for the number.
http://www.aacncclub.com/FORD_HEAD_CASTING.html
If you can see the casting number, here is a website with all of the casting numbers.
http://raceabilene.com/kelly/hotrod/engine3.html
Hope this helps,
later, mikey
my signature lines...not really directed at anyone in particular..
BE different....ACT normal.
No one is completely useless..They can always be used as a bad example
Old 05-08-2009, 12:26 AM
JeffB's Avatar
JeffB JeffB is offline
Last classified ad: 1965-71 Chilton A/C and...
SBF Heads
Click on this: [url]www.mre-books.com click on Ford books, probably would be a good idea to get the book.
Old 05-08-2009, 07:14 AM
woodz428's Avatar
woodz428 woodz428 is offline
Troll Hunter
The 2J14 appears to be the casting date code. That would have it cast on Sept 14,1972. Making it, most likely, a 1973 302 head.
Old 05-08-2009, 10:30 AM
mattmar's Avatar
As always thanks for the good info guys.
Similar Threads for: "66 ford mustang head identification"
66 mustang gauge cluster wiring harnessSouthernRascal39Electrical204-14-2009 10:19 AM
66 Mustang won't start, no lights, no instruments, batt good...danbeckElectrical301-25-2009 08:52 AM
66 Mustang front suspension upgrade66StangBoySuspension - Brakes - Steering2601-02-2007 04:32 AM
Ford Alternative Restomod Articledatson280zxturboHotrodding Basics105-31-2006 03:18 AM
3.8 Ford Head Gasket QuestionsRCastleEngine1704-11-2005 10:14 AM
