Hot Rod Forum : Hotrodders Bulletin Board > Tech Help> Electrical
Old 08-05-2011, 12:28 PM
hardtop racer hardtop racer is offline
68 camaro resistor wire,,help
what year did chevy stop using resistor wire ,i want update my system. good replacement electronic dist,??(without need to refinance) what guage wire to replace resistor wire?? is it enought to replace wire from firewall to coil??? does elimination off resistor wire require new coil??? i want to try a stock dist prior to risk my new coil,, what yr stock did not have resistor wire?? i need help i am 75 yrs old , like to ride in my 68 camaro once since i put 396 bb in. thanks
Old 08-05-2011, 02:22 PM
vicrod's Avatar
vicrod vicrod is offline
life is a ride
Last journal entry: 08
In 1975 GM changed over to HEI distributors. In 1980 they started to transition to commuter control.
The HEI is totally self contained meaning it has the electronics and the coil inside.
They are larger in diameter so check for firewall clearance.
Run a new #14 wire from the ignition to the dist.
Disconnect the yellow wire from the starter solenoid.
The HEI only requires a 12 volt source.
Summit, Jegs or GM performance parts are sources.
vicrod
Recent Electrical posts with photos
Similar Threads for: "68 camaro resistor wire,,help"
how do i install 69 camaro one wire alternatorboyd1stgencamaroElectrical111-20-2009 12:31 PM
65 Belair resistor wire or ballast resistor?sabino56Electrical708-16-2009 07:07 PM
question about ballast resistor and wire gaugeredneckprofessorElectrical2506-09-2007 01:50 PM
Where the resistor wire supposed to go ?Olds 69Electrical3302-08-2005 01:10 AM
how do I wire in a tacho on a CamaroDave RoseElectrical211-23-2003 03:38 PM
