Old 08-12-2011, 06:54 PM
midsota midsota is offline
Body Mounts
I am in the process of installing body mounts for a 1941 dodge. Currently making the brackets for the body mounts. My problem is locating generic rubber mounts that won't cost me an arm and a leg. What I'm looking for is a 2" diameter by 1/2" height and with 1/2" hole and locating boss. Any ideas out there? I found some on Oldcarstuff website but don't want to spend over $70 for 10. Thanks
Old 08-15-2011, 05:36 PM
RoyJr1987 RoyJr1987 is offline
Everything works if ya let it'
I would go to a junk yard and look at some of the body mounts on anything, to see what you could interchange with. OR, just search google, type in rubber frame mounts, and your size, plenty of info should come up. Hope this helps, let me know.
Old 08-15-2011, 07:45 PM
hp246's Avatar
hp246 hp246 is offline
I've never tried this trick myself, but some truck guys replace their worn body mount bushings with hockey pucks.
Old 08-15-2011, 08:50 PM
Body Mounts
Thanks for the information on the Body Mounts. I've found rubber material that are used by farmers in their barns for cows. It is call cow pads and comes in a short roll 5/8" to 1" thick. I can make my own for a fraction of the cost of manufactured mounts. A 2" hole saw works great. Thanks for all the suggestions though.
Jim
Old 08-16-2011, 08:15 AM
S10xGN's Avatar
S10xGN S10xGN is offline
Gotta love a turbo!
Last journal entry: Body on Frame today.
Have you tried Steele or Metro?
Russ
Old 08-16-2011, 06:08 PM
body mounts
Thanks! Checked out the web sites. For my application, I've made my own body mount brackets and will fabricate my own rubber mounts. Still can save a little money that way.
Old 08-16-2011, 06:44 PM
52fatness 52fatness is offline
Check on rubber rollers for boat trailers. They are fairly firm and I just bought one about 10" long that can be cut off to any length you want and it was like 9 bucks.
Similar Threads for: "Body Mounts"
Body Mountsmc73DD189Suspension - Brakes - Steering006-11-2009 08:08 PM
Body mountshrod34Body - Exterior203-14-2007 09:46 AM
2nd gen f-body mounts w/ picmeev182Suspension - Brakes - Steering405-05-2006 12:30 PM
body mountsastropsHotrodders' Lounge105-22-2004 09:58 AM
Body mounts38 specialBody - Exterior1204-26-2003 04:04 AM
