Old 09-03-2011, 09:19 AM
RoadSide Dan RoadSide Dan is offline
"Stranded, but not abandoned"
Body suggestions for Rat Rod
A friend of mine wants to build a Rat Rod using a 1987 Blazer frame.
What truck body or T-bucket would fit his frame with the least modification.
Thanks
RoadSide Dan
Old 09-03-2011, 10:06 AM
NEW INTERIORS NEW INTERIORS is offline
Set no limit's on yourself
Last journal entry: 41 WILLYS FRAME
Thanks
RoadSide Dan
Mr.Dan. The t-bucket would never look right on that frame because of the front end...It's so easy to buy some tubing and make a t-bucket frame... If you have a chop saw It would only take about a hour or so to build a frame....The tubing isn't that much.... You will be way ahead of the game then..
Old 09-03-2011, 08:43 PM
Old Fool Old Fool is offline
isn't an 87 blazer enough of a rat rod already?
Old 09-03-2011, 09:11 PM
babypp2 babypp2 is offline
Good luck guys.
Similar Threads for: "Body suggestions for Rat Rod"
LT1 balancer difference issues, F body to B bodyfast68Engine904-28-2011 02:29 AM
32 Ford body, firewall and body boltsheyjude076Body - Exterior511-20-2006 05:57 AM
Your suggestions on this body workcoachgeoBody - Exterior209-28-2006 08:17 AM
3rd Gen F-body rear discs on 65 A-body 12 bolt?smallblocker2Suspension - Brakes - Steering703-22-2006 12:51 AM
