Old 09-16-2011, 06:17 AM
mikej6 mikej6 is offline
32 top mount
Does anyone have the mesurement as where to put the lower mounting tab on 32 roadster body? this is the tab that the top mount to.
I need the measurement from door opening to center of the hole. then the distance from hole down to the body. also the size of the tab,HxWx thickness and the hole size and is it tapped?
MIKE
Old 09-16-2011, 02:09 PM
35terraplane's Avatar
35terraplane 35terraplane is offline
MIKE
Find Deuce and PM him. He should be able to help, he knows as much as anyone on the 32.
Bob
Old 09-20-2011, 06:20 AM
top mount
does anyone have Deuce email address so I can contact him?
or how do I contact him
Old 09-20-2011, 10:31 AM
Deuce
Go to search, Write Deuce, Go down to thread, 32 suspension, open that, go down about half a page, and you will find Deuce, click on the line under Deuce and it will ask you if you would like to PM him, click on that and leave your message he will get back to you.
Bob
Old 09-22-2011, 06:10 PM
Deuce Deuce is offline
Last journal entry: 32 3W
MIKE
The center of the hole is back 4 and 1/2 inches from the body edge. The hole is 1 and 1/4 inches high and NO ... the hole is not tapped nor round. It is square. It is 3/16ths thick.
These measurements were taken off my Henry Ford original steel 32 roadster and the Brookville roadster I have in my shop. I am working on it for a friend.
You can go here to see the bracket and it's placement.
http://www.wescottsauto.com/Body/bo...-1932Bodies.pdf
The bracket is available from Wescott or Brookville.
You can go here to see how the setup works
http://www.topsters.com/
Deuce ... Moderator
Sorry, I may have been a bit short with you...
I don't suffer fools well. I'm workin' on it
... NOT ...
Old 09-23-2011, 05:52 AM
top mounts
THANKS.
It is really nice to have a place to get inf. from knowledge people.
why is the hole square? and not round.
I like your cars.
How do you keep the gararge so clean???
thanks again
MIKE
Old 09-23-2011, 11:41 AM
Here is another photo ...
ORINIGAL 32 Ford roadster ...
Not my roadster but it is a old magazine cover roadster from the 60's.
I have no idea why the hole is not round. I would imagine the hole is broached ... and was possibly square to hold the bracket in place while being machined. I guantantee you ... HENRY had it square for a reason.
... NOT ...
Old 09-23-2011, 12:31 PM
Deuce I hope you don't mind that I sent mike looking for you, as I was sure you could answer his question.
Bob
Old 09-23-2011, 03:03 PM
Bob
Not a problem at all ...
We all have our own little area of knowledge and mine just happens to be 1932 Fords
... NOT ...
Similar Threads for: "32 top mount"
283 front mount convert to side mountjomilEngine1001-19-2007 09:09 AM
How much clearance should there be between motor mount and motor mount bolt?firstgearEngine306-09-2006 08:31 AM
To Re-mount or Not to Re-mount?fiftysix ChevyEngine101-27-2006 06:23 PM
MountTWOPLYMTransmission - Rearend107-08-2005 04:38 AM
In Car LCD MountwasabiInterior712-27-2003 09:31 PM
