2000 Suburban 4L60E problem
Just rebuilt the 4L60E because I had lost 3rd and 4th gears.
Air checked as I put it all together and everything checked out. Once I installed the trans., and test drove all I have is reverse and 1st gear. I cannot get it to shift even mannually. I pulled the wire harness off but it made no differance I still only get reverse and 1st. Can anyone tell me where I might have missed something? Register now (free) or login to remove ads |
are u sure its first and not taking off and staying in 2nd if if the sprag is in backwards or locked up or the clutches are to tight
You missed something. When the wire harness is unplugged the trans will default to 3rd gear in "D" if the trans is built correctly. Reverse is a function of the manual shift valve, not solenoid activated
At the Bonneville Salt Flats, first gear is known as 130 mph. |
| Similar Threads for: "2000 Suburban 4L60E problem" | ||||
| 1994 Chevy Suburban K1500 4L60e Transmission Problem | rmar2010 | Transmission - Rearend | 2 | 11-29-2010 03:08 PM |
| 2000 4L60E to an earlier 4L60E, What do I need to change out | aquaterrarv | Transmission - Rearend | 2 | 04-08-2010 06:22 PM |
| 2000 Tahoe W/4L60E trans problem | crackrbaby1 | Transmission - Rearend | 0 | 04-21-2009 08:12 PM |
| 4l60e problem 93 suburban | hecfrombx | Transmission - Rearend | 21 | 04-04-2009 07:40 AM |
| 96 Suburban W/4L60E | BICHN69 | Transmission - Rearend | 2 | 05-24-2005 10:43 PM |
