Old 12-28-2011, 07:01 PM
hotrodcommuter's Avatar
hotrodcommuter hotrodcommuter is offline
TX plates, CA license
650 avs dies with left hand turn
I have a 454 peanut port in my 65 impala, engine is GM crate, no mods, just edelbrock performer intake, and 650 avs carb. timing is good, 700r45, 4.11 rearend.
Here is current issue; acts like its going to die when I turn left, the car and all my clothes smell like fuel all the time. stumbles a 'little' when I take off from stop. I have checked the plugs, they all look clean and good. no leaks in fuel lines. I have checked the carb adjustments with a vacuum gauge to about 18. any advice on how to not smell like I didn't just dump gas all over myself?
Old 12-28-2011, 10:50 PM
68NovaSS's Avatar
68NovaSS 68NovaSS is offline
Last wiki edit: Working with chromed bolts
Last journal entry: Fresh paint
Wiki Edits: 9
Carb mounted sideways? Floats low?
''Life's tough, Pilgrim, and it's even tougher if you're stupid.''---John Wayne
Midnight Sun Street Rod Association
Old 12-29-2011, 02:58 PM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is offline
Yada Yada Yada
The smell is the gasoline over vapourizing. A common issue with AFB AVS carbs.
Its a carb heat management issue. Install a wooden carb spacer under the carb to reduce the heat soak issue. Block off any heat riser passage at the intake manifold. The fuel line must be routed away from heat.
The mechanical fuel pump should have a heat isolation gasket between it and the block. www.sealsit.com
The fuel float level is either too high or too low. The fuel pressure is a bit too high. 5 PSI idle fuel pressure is the max you need.
Fuel smell- carb heat soak:
This is why newer cars have a fuel vapour recovery/purge system w/ charcoal canister and return lines.
Old 12-31-2011, 12:25 PM
do you think I will be ok with the wooden carb spacer? I have zero clearance for anything else between the cleaner and the hood.
Old 12-31-2011, 12:27 PM
would I be better off with an electronic fuel pump, say onthe fender well? and fuel line routed 'above'?
Similar Threads for: "650 avs dies with left hand turn"
Left hand drill bitsWakBordr7387Hotrodding Basics2812-12-2007 01:43 PM
Light tap noise when left hand turn is madeBill RieseSuspension - Brakes - Steering511-29-2007 02:13 PM
Chevy heads right or left handmittleiderjEngine2809-12-2005 04:38 PM
right and left hand thread wheel studsswellwelderEngine1009-13-2003 07:36 AM
left hand alt brkt.shootdownEngine003-30-2002 09:14 AM
