Old 01-01-2012, 05:59 PM
rebel5994 rebel5994 is offline
350 not getting fuel
i have a 73 chevy scottsdale it has a 350 its not getting fuel i have tryed a new pump sending unit and priming it
any ideas?
Old 01-01-2012, 06:01 PM
also the fuel pump is on the motor
Old 01-01-2012, 06:52 PM
streetbruiser's Avatar
streetbruiser streetbruiser is offline
I once had a short piece of hose from the sending unit to the steel line on the frame sucking air. It was hard to find because the hose stayed dry. One of the craziest things I've seen.
Old 01-01-2012, 08:43 PM
ssmonty ssmonty is offline
X2 if your talking about the hose from the fitting on top of the fuel tank to the steel line on the frame. I'm pretty sure you are, I just put it different terms just in case the OP didn't know where the sending unit was.
ssmonty
Old 01-01-2012, 09:09 PM
Sorry I missed were he said he replaced the sending unit. Duh.
You can check the hose and connecting lines by hooking up a vacuum pump to the fuel line on the inlet side of the fuel pump and seeing if it will pull fuel without bubbles of air. If you don't have a vacuum pump you might be able to borrow one from Autozone?
Has the filter been changed?
ssmonty
Old 01-02-2012, 09:14 AM
T-bucket23's Avatar
T-bucket23 T-bucket23 is offline
Last wiki edit: Engine basic condition - how to check Last photo:
Wiki Edits: 26
Fuel line rotted, pinched or plugged somewhere. Disconnect it at the pump and use a compressor to blow air through it . You should be able to hear the air in the tank. A hole in the line somewhere will keep it from sucking fuel from the tank, old rubber line will suck air. If it is plugged most likely the air pressure will free whatever is stuck in the line.
Also check to be sure the vent isnt plugged, they is with the gas cap off
Artificial Intelligence is no match for Natural Stupidity
Chet
Old 01-02-2012, 12:59 PM
eloc431962's Avatar
eloc431962 eloc431962 is offline
Evil Wicked Mean And Nasty
Wiki Edits: 37
any ideas?
Does it start and run when you prime it ? And does it have gas in it ?
Cole
Old 01-02-2012, 02:07 PM
68NovaSS's Avatar
68NovaSS 68NovaSS is online now
Last wiki edit: Working with chromed bolts
Last journal entry: Fresh paint
Wiki Edits: 9
I've had new mechanical pump installs where the fuel has drained from the line. Took several priming with the short run time to get it to keep running. Have you filled the carb float bowls (through the vent tube) and run them out to give more pump "prime time"?
''Life's tough, Pilgrim, and it's even tougher if you're stupid.''---John Wayne
Midnight Sun Street Rod Association
Old 01-05-2012, 02:11 PM
task65 task65 is offline
Check the fuel pump rod that rides on the cam
Old 01-05-2012, 02:16 PM
eloc431962's Avatar
Wiki Edits: 37
X2 on checking the fuel-pump rod.
Have you verified fuel from the pump to the carb ? un-hook at the carb and see if you have coming up through the line to the carb JMO. But if it won't run by priming it hummmm!!!!!!!!!!!!!.
Cole
Old 01-05-2012, 02:20 PM
eloc431962's Avatar
Wiki Edits: 37
Could also be the Fuel Pump Eccentric. JMO
Cole
Similar Threads for: "350 not getting fuel"
V8 w/ carburetor + eletric fuel, runs too rich. Do I need a fuel pressure regulator?5_speedEngine1810-25-2009 01:51 PM
Locating Methods For Air Leaks In Mechanical Fuel Pump Fuel LinesJ.J. LASALLEGeneral Rodding Tech606-29-2009 01:04 AM
Quadrajet 4bbl/Edelbrock street fuel pump- too much fuel pressure?Bob TurnerEngine211-29-2008 11:50 PM
Mr. gasket micro elec. fuel pump enough fuel output for 400 skinny?stewartcannonEngine201-07-2007 03:52 PM
Fuel Cell-Tube Type Fuel Level Sending UnitsStupido1Engine306-11-2005 06:31 PM
