Hot Rod Forum : Hotrodders Bulletin Board > Tech Help> Transmission - Rearend
Old 02-09-2012, 07:28 PM
dwfleming dwfleming is offline
dwfleming
1985 1/2 ton pickup
will the tranny inter change with a 1989 1/2 ton??
Old 02-09-2012, 07:49 PM
Crosley's Avatar
Crosley Crosley is offline
Last wiki edit: T-350 rebuild tech
Last journal entry: Bar under the dash
Wiki Edits: 1,659
Are you talking about a manual shift trans or automatic?
4x4 or 2 wheel drive on each truck?
More info please
At the Bonneville Salt Flats, first gear is known as 130 mph.
Old 02-09-2012, 08:01 PM
dwfleming
transmission swap
will transmission from 1985 1/2 ton automatic 2 wheel drive 350 interchange with 1989 1/2 ton 2 wheel drive 350??
Old 02-09-2012, 08:15 PM
Crosley's Avatar
Wiki Edits: 1,659
dwfleming, you are new here. Please do not start multiple threads on the same subject.
I merged your two threads in to one here.
Old 02-09-2012, 09:21 PM
matt167 matt167 is offline
Last wiki edit: Ford axle ratio codes
Last journal entry: Rear Suspension
Wiki Edits: 31
2wd to 2wd or 4x4 to 4x4, automatics should work if there both 700-R4's. SM-465 4spd from an '85 will not correctly fit a '88-'98 truck if it's a M/T. 1500's got the old Getrag 5spd that year, the 3/4 and 1 tons still got the SM-465 for 1989 and 1990 but the shifter and output are diffrent than the earlier transmissions, and of course, the trans crossmembers are diffrent
Old 02-10-2012, 03:53 AM
123pugsy's Avatar
123pugsy 123pugsy is offline
Last wiki edit: Metal shaping
Last journal entry: MOTOR MOUNT ISSUES
Wiki Edits: 29
The trannies will both bolt up if that's what you're concerned about.
Of coarse one of them could be a th400 and the other a 700r4. In that case there would be more work involved such as drive shaft alterations, crossmember relocating, adding lock up controls, etc...
If they are both 700r4's, use the torque converter specific to the tranny and its a straight swap. I believe the earlier ones were 27 spline and the later ones were 30 spline.
Recent Transmission - Rearend posts with photos
Similar Threads for: "1985 1/2 ton pickup"
84 toyota 4x4 pickup, 91 s-10 2wd pickup, leaf pack distance?fast68Hotrodding Basics110-07-2010 12:40 AM
1985 GM Pickup Exhaust ?'s....brandon633Engine511-06-2003 11:45 PM
1985 GMC Pickup Suggestions...brandon633Body - Exterior310-09-2003 06:35 PM
1932 Ford Pickup and 1933-34 Pickup Different? YESpasadenahotrodTransmission - Rearend110-23-2002 02:20 PM
A 1946 dodge pickup with a 1985 front end?jazzguitarSuspension - Brakes - Steering306-18-2002 11:13 AM
