Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Shringer disc.
Thread: Shringer disc.
  #27 (permalink)
Old 12-10-2012, 10:56 AM
tech69 tech69 is online now
put up or shut up
they are very good for bedsides cause it's a big open panel. If you use something not as good as a shrinking disk you run the risk of overheatting it in a small localized area which then borrows the metal from somewhere else and you'll create a loose area adjacent to it. Obviously, using a stud gun you can easily get away with it by doing lots of light shrinks but still not as accurate at distributing heat like a shrinking disk, just faster.
