Shrink methods - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 06-04-2012, 08:04 PM
Old bodyman, you are right if all one want to do is shrink some metal so it isn't oil canning then cover it with plastic filler. But if one wants move forward in the tin forming skills you toss the shrinking hammer in the trash or grind it smooth like I did. It isn't perfectly smooth honestly because I have a lot of hammers and when I need a real nice smooth hammer I have others to use. This one is still for "roughing" out work.
You can do the exact same thing gathering metal with a glancing blow with a flat hammer. I am by no means a tin master, but I would like to be and because of that I will use the smoothest tools I can on the metal I am working with to the metal remains smooth.
  #17 (permalink)
Old 06-04-2012, 09:27 PM
Love the responce! Watched some videos and more that I found.
Quick question: Instead of my Oxy/Act torch (not done setting up)
Mapp gas o.k.?
Some pics from tonight.
Last one is from good side.
Name:	164 dent 008.JPG
ID:	65824   Click image for larger version
Name:	164 dent 001.JPG
ID:	65825   Click image for larger version
Name:	164 dent 003.JPG
ID:	65826   Click image for larger version
Name:	164 dent 005.JPG
ID:	65827   Click image for larger version
Name:	164 dent 007.JPG
  #18 (permalink)
Old 06-04-2012, 09:32 PM
Prof. T. Soggmeyer's Avatar
Plan B
Originally Posted by Nonhog
Thanks for all the reply's. Keep 'em coming. I find that I learn stuff going over the same thing when somebody phrases it different than I've read before.
I do lurk on a few metal sites. I like the All metalshaping the best.
I know I can learn this stuff I've been doing well at banging dents out its the ones with creases that are really hard.
I tried to blow up a pic as a "before" but to really understand I'll snap some pics tonight with a straight edge and maybe a pic or 2 from the good side.
Thanks again!
That looks like a volvo 164. I used to own one. Had it for a long time, that straight six was a screamer. I have a 264 now, still a nice car but not as much fun.
Brad...
  #19 (permalink)
Old 06-04-2012, 10:47 PM
Good eye!
The day we picked it up. Thinking it might be more of a hot rod w/ an LS swap.
Not in any rush. Have to finish the 5.0 Bertone swap 1st.
  #20 (permalink)
Old 06-05-2012, 06:12 PM
Plan B
Don't hurt that grill! you can't get em anywhere! My 164 was a rocket. My 264 sounds like a vacuum cleaner, still quick though and has 85,000 original miles.
Brad...
  #21 (permalink)
Old 06-05-2012, 06:38 PM
I always wanted a 262C
  #22 (permalink)
Old 06-05-2012, 06:46 PM
Our 262C is perfect for my wife. She's 5 feet tall. Its a bit tight for me I'm 6'
Cool thing is the body and interior are very nice. If I could just finish the 5.0 install. LOL
Never seen a blue one. NICE!
http://brickspeed.net/forum/showthread.php?tid=1784
So body experts if I manage to mangle my body work on this fender.
Would it be within reason to take a patch from another Volvo and weld it in?
I've done well on patches before. Just a thought?
  #23 (permalink)
Old 06-05-2012, 07:37 PM
You almost have it, just a little shrinking. Don't over heat and take it slow, it will take several attempts.
  #24 (permalink)
Old 06-05-2012, 07:44 PM
Wow, very cool!
  #25 (permalink)
Old 06-09-2012, 07:48 PM
rusthater89's Avatar
I recommend a shrinking disc. Once I used one I never looked back. I actually use it whenever I finish my hammer and dolly work. It really does the trick. The disc will target the high spots bringing them down lower and then you can beat the underside to bring the low spots up and repeat the shrinking application. It really helps to smooth out the hammer marks.
  #26 (permalink)
Old 06-10-2012, 10:55 AM
I've still yet to find what everyone finds so amazing about these shrinking disc. I have Wolfe's 4.5" disc and it's the most worthless thing I have in my toolbox.
  #27 (permalink)
Old 06-10-2012, 11:13 AM
123pugsy's Avatar
"Thread Cop"
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
Try a 7 or 8" one.
They do move metal quickly.
For the OP, try using a soldering torch first so you don't overheat metal. Just warm up about a 2" area and drop a wet rag on it and check if it moved.
Do not change the color of the metal.
Heat Shrink Vinyl... S10xGN Interior 7 10-21-2008 07:24 PM
How to shrink/stiffen a roof outlaw17 Body - Exterior 4 10-29-2007 08:35 PM
shrink or stretch and fill? modas Body - Exterior 4 12-20-2006 06:45 AM
Can I reverse shrink, by doing this? Ripped Body - Exterior 6 11-02-2006 10:12 PM
Using MAPP to shrink modas Body - Exterior 1 10-14-2005 12:37 PM
