-   -   Shrinking Disc Help, Please (http://www.hotrodders.com/forum/shrinking-disc-help-please-63518.html)
S10xGN 05-30-2005 02:59 PM
1 Attachment(s)
Hi all,
I'm doing quarter panel replacements on my '47 Ford and finally got a chance to use my shrinking disc, but I'm not sure I'm doing it right. After welding in the new panel, there is an outward "bump" along the top horizontal seam where the two panels were butted tight. I ran the disc along the seam several times but I'm not seeing any change. Am I asking too much? I've hit the seam and the areas about 2" - 3" on either side of it until the seam (high spot) turns blue...
John Kelly 05-30-2005 03:12 PM
Did you stretch the weld and the area that turned blue next to the weld and then smooth with a hammer and dolly after welding? The weld shrinks, so the disc is used later after the panel is smooth but high!
If the metal is turning blue with the shrinking disc, you have gone to far. It is only necessary to have the metal steam when it is quenched after using the disc.
It sounds like you might be expecting the disc to do what your hammer and dolly should be doing.
Let me know if this is not clear.
John www.ghiaspecialties.com
S10xGN 05-31-2005 09:36 AM
No, I guess not. I just butted the panel, tack-welded every 2 inches and welded it in (skipping around). I wouldn't know how to (properly) hammer a weld...
Oooh, magic word! "quenched" I wasn't aware that I was to quench the area after, I thought I was to let it air cool. Am I to use a wet rag?
FYI: I went back after allowing everything to cool down and it had indeed made a difference. I'll do the quench and wait a little longer...
Thanks!
Russ
John Kelly 05-31-2005 10:22 AM
Hi Russ,
Would you like a copy of my shrinking disc instructions? Just email me: ghiafab@msn.com
milo 05-31-2005 01:37 PM
With disk or tourch the shrinking happens during rapid cooling from a wet rag
