Is a shrinking disc what I need.....? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-29-2007, 07:44 PM
I recently replaced a quarter skin on my 69 camaro and got some warpage towards the rear. It's a section about 5 inches in diameter, and it bulges out not in. I've smoothed it out somewhat with hammers and dolly's nut i'm amatuer at best. So do I need to hit the inside of it with a shrinking disk.....thanks for any advice.
Old 07-29-2007, 07:50 PM
scrot's Avatar
Pictures?
Old 07-29-2007, 08:16 PM
Consider shrinking it with a torch. Heat a section the size of a quarter to red hot and lighlty hammer in a concentric motion around the hot spot working towards the middle. Let cool and check the results.
Old 07-29-2007, 08:42 PM
the torch should work if you do it right ....but if you dont your in trouble practice on the old q-panel first.
Shane
Shrinking Disc, first time used dwhitt Body - Exterior 1 06-08-2005 08:54 AM
Installing a shrinking disc sevt_chevelle Body - Exterior 5 03-26-2005 10:50 AM
What grinder needed for a shrinking disc sevt_chevelle Body - Exterior 4 02-27-2005 11:19 AM
Hotrodders Knowledge Cluster: Disc Brake Conversions Jon Suspension - Brakes - Steering 0 08-29-2003 04:34 PM
Shrinking Disc primerbaby Body - Exterior 1 03-30-2003 08:11 AM
