Shrinking disk - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-10-2004, 07:55 PM
adtkart@aol.com
Shrinking disk
I have seen several references to using a "shrinking disk" for sheetmetal repair. I have tried searching several ways, but cannot find them. Does anyone know where I can get one?
Old 05-10-2004, 09:27 PM
crazy larry's Avatar
Last journal entry: better comparison before and after shots
check it out.
Old 05-12-2004, 06:19 PM
adtkart@aol.com
Larry.... that link only takes me to another board. It does not tell me anyone that sells the disk.
Old 05-12-2004, 07:15 PM
i'm sorry. maybe you have to register for it to take you to the page i linked, i'm cookied, it might make difference.
anywho, it's instructions on how to make your own shrinking disk. and there's a link to a site that has some more info....
www.ghiaspecialties.com
on the forum page at metalmeet, scroll down to 'metal shaping tutorials' and click on "make your own shrinking disk".....
Old 05-13-2004, 12:39 AM
Randy Ferguson's Avatar
Ferguson Coachbuilding
Last journal entry: '41 Chevy sedan
shrinking disc 101
Hi Guys,
I had to repair a good sized area of a '34 Chrysler fender last night before proceding with the replacement of some badly damaged metal. I prefer to repair all I can before a final decision is made of what to replace. There has been some discussion lately concerning shrinking discs. I wish I would have tried one years ago. It would have saved many headaches!!
This fender has had a hard life, but it can be saved. Some replacement is necessary, but most of the badly repaired metal is still decent enough to work with.
If you look closely, you will notice that the previous repairer use one of those metal mutilating shrinking hammers. WHAT A HOAX!!
He also used a course grit grinding disc to remove the paint and probably to remove some of the scaring from the hokey shrinking hammer. Still, it's not beyond repair.
To reveal the high and low areas, a large magic marker is used to ink the entire damaged area.
Rubbing over the surface with fine sandpaper on a block will reveal the highs immediately. As you can see, it's really bad in some spots with general wavyness throughout. This particular area is all stretched and in need of excessive shrinking. I started by running the shrinking disc over it lightly a few times, followed by water quenching. In extreme cases, the metal will turn blue, but that should be avoided if possible. After the metalhas started to shrink some, The slapper and dolly is used to further refine the surface. I place the dolly on the inside of the panel and lightly tap with the slapper on the outside. If you hit the dolly, it will ring. This will show you the placement of the dolly. You can then steer it to wherever you want it. I try to stay off the dolly, so I know I'm not strtching the metal further. Keep the dolly directly against the low spots and work around them wiht the slapper. The mass of the dolly will force the low spot to rise and the light blows from the slapper will knock down the highs. Once the panel feels smooth, The shrinking disc can be put to use again to smooth the area out even further. You only stay on the surface wiht the disc for a few seconds, then allow it to cool, either by water or air quenching. You can speed up the process if you decide to air quench by using compressed air to blow cool air across the surface. I use a squirt bottle to water quench. Less mess that way. A little bar soap on the disc will minimize galling of the metal. The disc should glide across the panel and not remove any material.
After several passes over it with the disc and lightly working the highs and lows with the slapper and dolly, here are the results. I have gone over it with fine grit sandpaper to polish it up a bit for the picture. This gives you a better look at the reflection from the lights. It's not 100% perfect yet, but it's good enough to begin the metal replacement.
I have right at 1 hour invested in this repair. I don't believe this could be fixed any faster with body filler.
Randy Ferguson
Metalshaping & Kustom Paint
www.metalmeet.com
Randy Ferguson
www.metalmeet.com
Old 05-13-2004, 02:42 PM
gt2betubbed's Avatar
Kid With A Wrench...
Last journal entry: The Blower and test fit.
Please forgive my ignorance, but what is a "shrinking disc"?
I saw your post Randy and the picture of it, but I don't understand what it is nor how it works. Is it a disc that you put on a grinder and actually "grind" on the metal to help shrink it? I've been doing so much reading on metal fabrication because my project has come to a complete halt because I'm intimidated on starting my firewall. Great looking work though! Every post of your's I've seen has been very inspiring!
Old 05-13-2004, 05:03 PM
milo's Avatar
point on positive
I remember a guy selling theses things 25years ago. He called them the "Incredible Shrinking Disk"...
I've been watching this thread for WHERE TO BUY ONE ?
too...
Old 05-13-2004, 05:27 PM
i'll sell you one for twenty bucks plus shipping.
Randy, i need to order like oh, ten shrinking disks. i'll give you 12 bucks each?
Old 05-13-2004, 08:30 PM
where to purchase a shrinking disc
Hi Guys, please read each post in this forum. Larry has posted two sources for them. One is for $50.00+shipping and the other is a tutorial on how to make one yourself. They are also available from Sunchaser Tools, but they are made differently than the other two you will see and are much more expensive.
It's just a piece of 18ga. stainless steel with a 1/4" flange tipped around the edge. You run it at 6,000rpm over the surface of the stretched panel. No material is removed. In fact, one could asume that it actually thickens the metal, since it is generating heat and forcing the metal to gather into itself. In my mind, this would cause a thickening of the metal by a slight degree. Not worth debating though.
gt2betubbed, Thanks for the encouragement!
Randy Ferguson
www.metalmeet.com
Randy Ferguson
www.metalmeet.com
Old 05-13-2004, 11:16 PM
milo's Avatar
point on positive
The original "Incredible Shrinking Disk" had cooling fins on the back side of it. It kinda looked like a fan clutch...That one might work for a while though
Old 05-13-2004, 11:34 PM
Milo,
The original Incredible shrinking disc, as I've seen it has a flutted edge. I suspect it's mostly to keep it from getting a wavy edge, more than cooling qualities. Unless we're talking about two totally seperate deals. The smooth shrinking disc works great and it's actually better on aluminum than the one with the flutted edge.
Randy
Randy Ferguson
www.metalmeet.com
Old 05-14-2004, 12:01 AM
unstable's Avatar
Murderator
Last journal entry: Brackets, Stories and the future
Randy,
correct me if I am wrong here...but technically can't you just skip the portion of the instructions where you put a "lip" on the edge of the disk?
I mean, I thought the only functionality of the lip was to stop it from becomming a giant cutting device.
Old 05-14-2004, 12:08 AM
The safety issue is definitely one reason, but it also adds strength.
Randy
Randy Ferguson
www.metalmeet.com
Old 05-14-2004, 07:31 AM
unstable's Avatar
Murderator
so just for the sake of arguing. If someone wasn't interested in building a shrinking disk that would last forever...couldn't they just cut a circular piece, drill a hole and slap it on their grinder?
Old 05-14-2004, 09:00 AM
walt's Avatar
For a small job all you have to do is flip over a regular sanding disc and use the back side. It will provide enough heat to do the shrinking.
