Shrinking hammers & dollys, and shrinking in general - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-10-2004, 09:38 PM
I've got a pile of body working hammers and dollys, including a shrinking hammer I bought.. I'ts been a while, and I did most of my learning (especially about shrinking) through trial and error (about 10 years ago). Anyway.. I don't have a shrinking dolly, is it necessary to have both hammer and dolly? What should I know/bear in mind having a full assortment of regular dollys except for a shrinking dolly, plus having a full assortment of hammers and spoons.
Also, are there any good guides on heat shrinking (especially about where I want to pick my spot to shrink, and how big of an area to shrink at once?) I suspect I've forgotten everything I learned through trial and error years ago aside from how to heat then cool to shrink metal.
Old 05-10-2004, 09:51 PM
Randy Ferguson's Avatar
Ferguson Coachbuilding
Last journal entry: '41 Chevy sedan
Hi Slipangle,
In my opinion, your best bet would be to take your shrinking hammer straight to the forge and make a useful tool of it! Same goes for shrinking dollies. It just gimmicky crap!! You're number one tool for shrinking should be a shrinking disc. There is a message posted already about this tonight. Have a look at the shrinking disc topic for more details. If you want to learn how to use one, let me know and I'll be happy to post a tutorial on how they are used.
Randy Ferguson
Metalshaping & Kustom Paint
www.metalmeet.com
Randy Ferguson
www.metalmeet.com
Old 05-10-2004, 10:21 PM
mitmaks's Avatar
Last journal entry: Grille
usually only auto body pros can use those, theyre kinda hard to use and if you dont know how to use them you can get more damage than fixing. I just use oxyacetylene setup for shrinking metal.
Old 05-11-2004, 12:11 PM
unstable's Avatar
Murderator
Last journal entry: Brackets, Stories and the future
shrinking disks aren't hard to use, and the nice thing is that you are far less likely to over-shrink using a disk than using a torch. With a torch you are putting so much heat into such a small area...you're just asking for trouble.
The shrinking dollies do work also, although they come at a cost. It really eats away at the metal when you use them.
Old 05-12-2004, 06:22 AM
jimk's Avatar
I have used a stud welder gun with a shrinking tip on it.Works great,especially if you have an "oil-can" problem.
